1972 Original Paint - NCRS Discussion Boards
1972 Original Paint
  • Dan A.
    • February 1, 2004
    • 212
    1972 Original Paint
    I just purchased a 28,000 mile Ontario Orange 72 coupe with original paint. It looks very nice for a 41 year car when it is outside but not quite as good under the flourescant lights in my garage. The paint has some minor checking and feels a little rough. Assuming it is indeed original, is there any particular product that would help the old lacquer paint shine a bit more? I don't want to get too aggressive as I realize the old lacquer finish is pretty fragile.
    Or maybe I should just change the lights in my garage!
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 1972 Original Paint
    Try a claybar. is the VIN deriv. 6574? If yes, that was my car.
    • Roy V.
      • April 8, 2008
      • 309
      Congrats on the new family member , Wow only 28,000 miles in all those years!
      As Harry mentioned above a good clay bar session would be the first step in a paint correction process (after a good washing) claybar will remove any old wax and most contaminents, use plenty of soapy water when doing the clay bar. After that a good sealant or wax of your choice should yield good results, if, after that, you still feel the shine isn't up to snuff you can always go to a professional detailer who will use a machine to get the paint looking real good. Remember if its still the original paint, it's never going to be as shiny as modern day base coat, clear coat paints
      Ontario Orange was one of 3 firemist colors, the other 2 being Steel cities gray and War bonnet yellow that you got in 1972.
      Would love to see some pictures, when you can.
      Regards
      Roy
      1972 LT-1 Elkhart Green Coupe
      • Dan A.
        • February 1, 2004
        • 212
        Harry - It is #7074.
        Roy - Thanks for the suggestions. I'll put some pictures up this weekend.
        • Chris H.
          • April 1, 2000
          • 837
          Concur...clay bar followed by wax/cleaner followed by pure carnuba wax. I use Mother's products.
          • Ron G.
            • December 1, 1984
            • 865
            Be cautious, as if it is the original lacquer, anytime you rub anything on it it will move and separate the properties of the lacquer paint. Just my 2 cents, DO NOT TAKE IT TO A PROFESSIONAL DETAILER. As that may be fine an everyday car or a base coat clear coat, they usually get too agressive and could cause either damage or ruin what is left of the original factory paint. Once it is gone, it isn't coming back.
            "SOLID LIFTERS MATTER"
            • Dan A.
              • February 1, 2004
              • 212
              SDC11923.jpgSDC11927.jpgSDC11928.jpgHere is the 72 after a few hours of work. I started with the clay bar, then Meguiars Ultimate Compound, then Pinnacle Souveran wax. I was pretty happy with the results. Thanks the suggestions.
              • Mike E.
                • June 24, 2012
                • 920
                Beautiful car!
                Mike
                • Bill S.
                  • April 30, 2002
                  • 154
                  Do not use a clay bar. The paint is too fragile. For more information on the subject read this article
                  The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints Restoring original and antique paint In the collector car hobby world, there’s a lot of interest in restoring and preserving original paint on classic and antique cars. Restoring the original...
                  The solution is a product that came out in the 20s and still sold today Meguiars #7 Show Car Glaze (formerly known as Sealer Reseal Glaze)
                  Bill Strobel
                  Owner Independent Towing
                  Fayetteville, NC
                  1979 Corvette White/Red L-82 4 spd
                  Only 4,200 miles
                  Do It Right or Don't Do It At All
                    • 11668
                    Originally posted by Bill Strobel (37873)
                    Do not use a clay bar. The paint is too fragile. For more information on the subject read this article http://www.autogeekonline.net/forum/...ge-paints.html The solution is a product that came out in the 20s and still sold today Meguiars #7 Show Car Glaze (formerly known as Sealer Reseal Glaze)
                    Ironically, the article you cite says to use a clay bar before using Meguiar's #7.
                    Perhaps you should read the article again?
                    Otherwise I do find it an interesting article.
