C3 Body Dolly - NCRS Discussion Boards
C3 Body Dolly
  • Jeff P.
    • 799
    C3 Body Dolly
    I've searched ,but find a lot of C2 input. Does anyone have a diagram of a dolly for a C3 Body lift? Thank You
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Michael G.
    • January 1, 1997
    • 1251
    Re: C3 Body Dolly
    Same as a C2 with slight extension off the front box to catch the radiator support area of a C3. I'll see if I can't come up with pic of a modified C2 dolley.
    • Steve W.
      • March 1, 2002
      • 78
      Re: C3 Body Dolly
      I think it's Nolan that has a great diagram in his restoration book. Same as C2 with the front extention to catch the radiator support asMichael said.
      • Michael G.
        • January 1, 1997
        • 1251
        Re: C3 Body Dolly
        Jeff,
        Images here were taken many years ago but believe you'll get the gist. The 'extension' you would need to add to front box would catch the radiator support area of a C3. You do not have to use the actual radiator support between the front fenders. I made up a light gauge metal support that bolted between the inner fenders.
        • Jeff P.
          • 799
          Re: C3 Body Dolly
          Thanks,guys. I'm not prejudice but its nice to see a C3 on a Dolly. Most I ever see are C2s. Ill take a closer look,but nothing in the back I see . Do you bolt the car onto the dolly?
          • Michael G.
            • January 1, 1997
            • 1251
            Re: C3 Body Dolly
            No need to, body rides on dolly. On later convertibles did incorporate a strap attached at the striker jamb then attaching at the door hinge to support rear of car.
            • Mark D.
              1984-96 Team Leader
              • June 30, 1988
              • 2162
              Re: C3 Body Dolly
              Jeff
              i'll give you one if you come to KY to pick it up
              Mark
              Kramden
              • Michael G.
                • January 1, 1997
                • 1251
                Re: C3 Body Dolly
                Jeff
                Mark
                Body is looking good Mark......like that Primer sheen
                • Mark D.
                  1984-96 Team Leader
                  • June 30, 1988
                  • 2162
                  Re: C3 Body Dolly
                  Thnx Michael...it looks more like this today
                  Kramden
                  • Michael G.
                    • January 1, 1997
                    • 1251
                    Re: C3 Body Dolly
                    Interesting...............check this out Mark! So sorry Jeff, couldn't resist.
                    • Mark D.
                      1984-96 Team Leader
                      • June 30, 1988
                      • 2162
                      Re: C3 Body Dolly
                      Groovy...beautiful!!!
                      Kramden
                      • Jeff P.
                        • 799
                        Re: C3 Body Dolly
                        Thanks, Mark. I have a heavy duty dolly that I'll add the extensions . Beautiful car.
