WCFB replacements for 57 dual quad - NCRS Discussion Boards
  • Theodore K.
    • December 1, 1985
    • 214
    Has anyone replaced the WCFB's on the dual 4 barrel 270HP engine with another brand 4 barrel? I think the WCFB was a 440CFM (going from memeory) carb so the pair should flow at 880 CFM. Getting jets, etc for the old Carter is harder and I am thinking about replacing the carbs themselves with a newer pair that would bolt right up to the intake. Of course that is more departure from original but this is a driver and several things are not original alreadyl Comments appreciated.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: WCFB replacements for 57 dual quad
    Theodore,
    One might be clever to remove the dual quad set up and set it aside. A single quad configuration and manifold swap will give you a wide selection of carbs to use. Anything from a Carter AFB, WCFB, Holley or Rochester, even a Q-Jet!
      Ted -
      No other 4-barrel will fit the C1 2x4 WCFB manifold - it was designed specifically for the WCFB, and no other carburetor will fit it. WCFB's were 390 CFM.
      • Steven B.
        • June 30, 1982
        • 4004
        Ted, if you want to keep the WCFB's the carb sources that advertise in the Driveline have parts. I have used them before. Good Luck! Steve
        • Tom B.
          • March 1, 1978
          • 720
          http://www.chucksmithandco.com/ has jets of all sizes and most any other WCFB part you could need. They built a set for a Hot Rod Magazine project a few years ago where they increased the cfm of the carbs considerably. If I remember right they modified the throttle plate with larger butterflies. The manifold was probably bored out to match also. Give them a call if bigger WCFBs are what you are looking for.
          Tom
          • Steven B.
            • June 30, 1982
            • 4004
            Tom, aren't you supposed to be at work?
            • Tom B.
              • March 1, 1978
              • 720
              You caught me. I woke up with the creeping crud this morning so I stayed home today.
              • Steven B.
                • June 30, 1982
                • 4004
                Uuuuugggggggghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh--
                • Tom B.
                  • March 1, 1978
                  • 720
                  Pretty close but I never maid it to the couch. (And I only dream of when I had that much hair).
                  • Tom P.
                    • April 1, 1980
                    • 1815
                    At one time, there was a carb adapter plate (maybe made by Mr. Gasket?????????) which permited installing AFB carbs on a GM 2x4 manifold. The adapter plates were slightly offset to space them slightly further apart. I know this for a fact, because Joel Miller (are you out there Joel?) had me rebuild a pair of AFBs that he has had forever on a GM manifold. Unfortunately, it never occured to me to take pictures of the manifold/adapter plates/AFBs assembled together. If I think of it the next time I go up to Tulsa, maybe I can stop by Joel's and take some pictures.
                    • Tom B.
                      • March 1, 1978
                      • 720
                      I remember those. I ran an AFB on my '56 Bel Air on the stock manifold with an adapter. The local Hires Auto Parts store had them in standard and offset. I don't think that the Mr. Gasket brand name existed when I bought mine. It seems like there was another company that either became or was bought out by Mr. Gasket.
                      Here's a straight up adapter but I haven't found an off set one yet.
                      Tom
                      • Steven B.
                        • June 30, 1982
                        • 4004
                        You are correct Tom. I had thought about running AFB's in '66 and found the adapters through Hire's and J&G Speed Shop in Ft. Wayne and Standard Auto Supply in Detroit. Didn't do it because didn't have money for the carbs. Probably a good thing.
                        • Tom B.
                          • March 1, 1978
                          • 720
                          You could buy a brand new pair of matched 409 AFBs at JC Whitney back then for around a hundred bucks. It seems like they were selling an intake with carbs, linkage and air cleaners for $139.95 for a small block. A lot of money at the time.
                          • Tom P.
                            • April 1, 1980
                            • 1815
                            Whaddaya mean "at the time"???? It still is a lot of money!
                            • Tom B.
                              • March 1, 1978
                              • 720
                              Point well taken. That's still more than my weekly allowance.
