First judging on 63 Conv. - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    A friends 63 was judged yesterday by the St Louis Chapter . It was a fun day , Everybody was nice and the event was well planed . The car did get a top flight . My question is two things were brought up ,one is in the judging manual and is not correct . It says 63,s after vin # 11,000 had light gray fiberglass . This car is a St.Louis car and is # 20937 and has light gray doors with the rest being white glass including the floor pan & inner fender skirts. I installed a new left qt. panel ( light grey G.M part ), all other panels are white as built . I do have photos of it stripped . The next question is not in the manual . The head lamp mounting panel has two large center holes used to mount the header cross flag emblem .
    This car has a lip or a flange area around the inside of the hole . One of the judges said it should be just a hole with no flange . I know its the original . He also said The rivits at the hood strikers were wrong ? again its the hood it was built with .Does anyone have any thoughts on this . Thanks Bill
  • Marco H.
    • March 1, 2002
    • 218
    Re: First judging on 63 Conv.
    Bill,
    Currently I am working on '63 # 94XX. The body is unhit and has no signs of any panel replacement what so ever. The only 3 pieces that are light gray glass are the hood surround and both rear door post covers (lower part of B-pillar, where door striker is mounted.) Other than that the entire body is "white" (Ivory). I am not a '63 expert. It is my understanding that over time more panels were produced in light gray and introduced into production. Which ones- and at what time, I don't know. The header bar from 1963-1966 typically have emblem holes with a flange/lip. Even very early '67s used a '66 carry-over headerbar that was re-punched to fit the '67 emblems (studs are closer together.) The headerbars with flat holes typically are '67 production or service replacements.
    Hope this helps.
    Marco
      • 6960
      Bill , I have a friend with gray fiberglass and his Vin is about 15xxx I am not sure theres even a white panel on his car. and he has no tool box tray. does this car have a tool box?
      And my 63 vin 106xx is a mix of white and gray panels with tool box trays.
      I never quite understood the rivit thing on the hoods big rivits or small rivits?
      • Harry S.
        • July 31, 2002
        • 5349
        April built 63. All gray except the rear deck. Holes should be a flange as you said.
        • Bill W.
          • March 1, 1980
          • 2000
          thanks Ed . no tool box
          • Bob J.
            • December 1, 1977
            • 720
            I think the header bar holes should have a flange or lip. Bob
            • Harry S.
              • July 31, 2002
              • 5349
              How about a picture of the rivets.
              • Gary F.
                • August 29, 2010
                • 248
                Hit the link for the discussion on 63 body panel color.https://www.forums.ncrs.org/showthre...=gary+fronczak
                • Bill W.
                  • March 1, 1980
                  • 2000
                  How do I post photos from a digital camera card ???
                  • Monte M.
                    • January 1, 1991
                    • 687
                    I do not mean to change the thread topic, but can someone post a few pictures of cars with both colors of glass.
                    I have had two 63. Both white glass. I have worked on 8 to 10 more without paint. All were white glass. What are the odds of all the cars I have worked on all being early cars?
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Here ya go, look at the deck.
                      • Gary F.
                        • August 29, 2010
                        • 248
                        My car is a March 18th build. Tail panel, both door striker panels, and drivers side door hinge panel were light gray.
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Bill,
                          First you need to get the files off your camera and onto your computer. Once you have that done, read this FAQ:
                          https://www.forums.ncrs.org/faq.php?...faq#faq_photos
                          Joe
