68 Hood questions - NCRS Discussion Boards
68 Hood questions
+ More Options
Posts
  • Jeff P.
    • 799
    68 Hood questions
    Starting to dissect the incorrect 68 convertible with the correct 68 coupe. 1st , the driver side hood latch. There are provisions for a spring. The Survivor doesn't have it .the convertible does. 2nd, the hood latch cable has two mounting points with clips. One in the middle and another between the middle and the passenger hood latch. What year hood did they stop using the second mounting point? I have come to the conclusion that I have an incorrect hood.it doesn't have the second mounting clip. Many thanks again. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Jeff P.
    • 799
    Re: 68 Hood questions
    I forgot to add the pics.
      • 43285
      Jeff-----
      The "one clip" cross cable hood was introduced in very late 1969 (after about September, 1969). The hood latches and latch bolts also changed at the same time.
        • 43285
        Jeff------
        There were 3 different upper latch sets used for 1968. The one you pictured looks like the last iteration for the left side. There should be a spring on the end of the release arm extending to the anchor point adjacent to one of the mounting holes. This style latch was never originally used with the "one clip" cross cable hood.
        You did not picture the right side latch. That could be important here, too
        • Jeff P.
          • 799
          Thank you Joe, on the latch spring question, they started using the spring late 69 ?
            • 43285
            Jeff-----
            No, the spring was used throughout 1969 and, I believe, for at least the later 1968's that used the 69-style latches.
            • Kurt B.
              • July 31, 1996
              • 971
              Joe, Is a May 10 built 68 considered mid or late? Should my May built car have the spring on the driver side (left) latch? Thank you Kurt
                • 43285
                Kurt-----
                With respect to the hood latches, I would say late. I believe it had the spring.
