67 Dash Harness Replacement - NCRS Discussion Boards
  • Matt T.
    • May 22, 2011
    • 18
    Hi Guy's
    I'm hoping someone will have a simple solution to this problem. I'm replacing the dash harness on my 67 coupe with a M&H unit. I cannot get the metal lamp holders to fit into the holes in the back of the instrument cluster. It seems that they are very close to seating but I just can't apply enough force to get them in.
    Is there a trick in getting them to fit?
    Matt
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 67 Dash Harness Replacement
    You might try wiping the hole edges and holder "fingers" with a lubricant like WD40.... just enough to have a slight film.
    • Matt T.
      • May 22, 2011
      • 18
      Thanks for the reply Stephen. Unfortunately the holders don't have fingers, they are solid with rounded edges where they fit through the hole. I'll give the lubricant a go but I think it will come down to a method of levering the holders into place. I was hoping that someone had already figured it out.
      Matt
      • Jim D.
        • 2884
        I just put all M&H harness' in my 65. I didn't have any issues with the bulb holders but they should be tight. Start them at an angle and push them in as you straighten them up.
        • Paul J.
          • September 9, 2008
          • 2091
          You might also want to rock them back a forth while doing this.
          • Stephen G.
            • January 1, 2002
            • 304
            No problems with the Lectric Unlimited harness (with resect to your problem). In fact I would consider mine too loose.
            Steve Gansky
            Newtown, (Bucks County) PA
