Canadian Delivered Corvettes - NCRS Discussion Boards
  • Brian W.
    • September 30, 1990
    • 216
    I have a '68 Canadian delivered corvette, originally sold in Scarborough, Ontario at Golden Mile Motors Limited. I have the GM Canada documents listing all options and colour. In the new judging manual on page 73 it says a Canadian-Export label should be affixed below the emissions label. Does anyone know where I can get one? Thanks.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Canadian Delivered Corvettes
    Surprised to see that someone is making them given that it's government issued and controlled. Also, I thought the label was affixed to the rear of the drivers door in the upper left corner. Maybe this is just later cars.
    • Brian W.
      • 216
      Michael:
      Judging manual states the label is affixed to the firewall above the master cylinder. Unfortunately I have never seen one so I don't know what they look like.
      • Jason R.
        Infrequent User
        • December 31, 2009
        • 18
        Brian: I believe the decal is the General Motors of Canada Ltd white and black decal that has the engine oil recommendations. It was put on just below the emissions label on the firewall.
        • Michael W.
          • April 1, 1997
          • 4290
          That's what I was thinking too.
          Brian-
          Here's what an original Transport Canada import sticker looks like, and it's placement at least for a July '73 car.
          • Michael J.
            • January 27, 2009
            • 7157
            Were the A.I.R. emissions systems deleted on the '68 Canadian Corvettes like other cars?
            • Michael W.
              • April 1, 1997
              • 4290
              No emissions equipment was ever deleted on any Corvette delivered to Canada, or any other car I'm aware of. Our standards have always been the equivalent of US Federal (49 state) regulations.
              • Michael J.
                • January 27, 2009
                • 7157
                Quite a few GM and Ford cars had the emissions systems deleted from Canadian and export vehicles in 1968, after that, no. You may want to read this:
                Where it says,
                "In 1968, vehicles exported to Canada and other countries did not require the AIR system. RPO KD1 was used to delete the system (if it would have been so equipped otherwise) and 1/4"-18 NPSF straight pipe thread plugs were installed in the manifolds. It is unknown if a credit was issued on the Canadian window stickers for this delete. The Controlled Combustion System was still installed on the exported L6 automatic and small block automatic cars.
                In 1969, Canadian cars used the same emission controls as U.S. cars."
                Also most all Fords had their Thermactor pump and injector systems deleted as shown on the build sheets and Marti reports, except for the 428 CJ, in 1968 too.
                • Brian W.
                  • 216
                  Michael:
                  Documents from GM Canada do not list option KD1. Only options listed:
                  A01 glass - tinted - all windows
                  G81 differential carrier - positraction
                  L79 engine: 327 cu.in. - spec high-perf (hyd lifters) 350 hp-v8
                  M21 4 speed manual transmission - close ratio
                  N11 off-road service exhaust
                  N40 hydraulic steering
                  PT7 F70-15-4 PR tire - spec nylon - white stripe
                  U15 speed warning indicator
                  U69 radio - AM-FM pushbutton
                  V48 engine coolant - increased protec (antifreeze)
                  Still would like to know where I can get that export label.
                  • Michael J.
                    • January 27, 2009
                    • 7157
                    OK, I guess the Corvettes were treated differently than other GM and Ford cars. Sorry, didn't mean to hijack the thread, just curious about what to look for on '68 Canadian Corvettes.
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      Is the vendor in the link I posted no longer selling them?
                        • 15621
                        My assUmption is that Brian is looking for the Canadian oil spec label for the area above the brake master cylinder, and no longer is looking for the transport label for the door, but it is somewhat of a leap on my part since Brian is a man of few words.
                        Edit add: That door location for the transport label is where I have seen 1968-1972 Canadian delivered Corvettes, but then we don't see so many south of the border.
                        • Brian W.
                          • 216
                          Michael:
                          I will check on this label tomorrow and if available I will order it but still looking for the one over the brake master cylinder. Thanks again.
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            If it's the Engine Oil Recommendation label sticker you're looking for as suggested by Jason and Terry, here you go:
                            • Troy M.
                              Infrequent User
                              • January 1, 1994
                              • 3
                              Been a Lurker for years, but since I feel I have something to add to this topic, this is my first post so.... I lived in Toronto from 91-95 and acquired a Canadian Export 71 LT-1 while there. I researched these labels with various folks while I lived there and found there were at least 3 different versions of this label. I removed (partially) an original label from a 73 Lemans and used it as an example to create two different versions. I don't know how to post pictures so if someone will PM an email address I will send a PDF file that shows these three labels (1 original, and the two labels I created). I created these with a CAD system in the late 90s so it would be much easier to recreate these with today's computer technology. I still have a few labels left that anyone is welcome to if they want them. I used one of these when my 71 LT-1 was judged in 1998. Thanks, Troy Marquis
