66 odometer test - NCRS Discussion Boards
66 odometer test
  • Jim S.
    • March 1, 1986
    • 1408
    66 odometer test
    I was just reading through the TD this morning and came across this post.
    Reply Reply With Quote
    March 30th, 2013, 10:42 AM#21
    Dick Whittington (8804)
    Re: Odometer roll back
    Originally Posted by Joe Ciaravino (32899)
    C4 Corvettes, and probably all other cars of the era use a thin mylar tie-bar instead of the old inking. The tie-bar is perforated in 5 places, attaches a lug on each of the tumbler drums, and keeps all of the tumbler drums aligned. If the odo is run backwards, the mylar tie-bar breaks and the tumblers become misaligned, resulting in the numbers in total disarray.
    I don't see how it's possible to tamper with a C4 odo, including R & R in under an hour.
    There is a similar tie bar on your mid year. You can take the needle type tools I referenced and manipulate the numbers on the drum. There used to be many masters that could do this before you blinked your eyes. I saw a set of those needles a few months ago. If I can run up with the guy that owns them, I will make a photo and post it................................................ .................................................. .................................................. .................................................. .................................................. ..........................................
    So now I am afraid I might have done something wrong in regard to my odemeter . When I removed my cluster several years back ,I did indeed roll the odometer back to zero ,as I assumed it was understood that it was going to be a complete frame off resto and therefore allowed.
    I truley don't remember how I did it , but I assume I just rolled it back by spinning the gear . I am QUITE CERTAIN I didn't use any needles or special tools ! Now based on Dick's comment about there being a "Tie Bar" on it , I am wondering if I broke it by doing so , and more importantly, that it won't work properly again !
    I surely don't want to find out after I install the cluster . So my question is : How do I find out if I broke it , or if it will work correctly again before I install the whole cluster back in the car ?
    One step forward , two steps back !
    Jim
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 66 odometer test
    After my total frame off restoration of my 67, I reset my odometer to zero. The odometer was inop when I purchased the car in 82 so the mileage was incorrect anyway. The odometer now has about 125 miles registered without a problem. I don't think you'll have any trouble with yours.
    • Jim S.
      • March 1, 1986
      • 1408
      Thanks Stephen,
      As they say " from your lips to God's ears " !
      So if I hear you correctly , you also used no special tools , and just rolled it back by spinning the gears , which is how I assumed I did mine ?
      Jim
      • Stephen L.
        • May 31, 1984
        • 3159
        Don't remember exactly... no special tools. Just had to get the "cogs" in the correct place so the cylinders would roll over correctly, so that the miles would register correctly.
        • Jim S.
          • March 1, 1986
          • 1408
          I am sure I had to get the cogs in the correct place to get the cylinders to spin as well . Heres hoping your right ,and they now register the miles correctly as well !
          Thanks again Stephen,
          Jim
