1954 hot restart needs full choke -- what is normal? - NCRS Discussion Boards
  • Peter R.
    • June 19, 2011
    • 233
    After my '54 is fully warmed up and then turned off, I have difficuly restarting it unless I give it full choke. (After it restarts, I turn off the choke immediately and it idles and runs fine.) Is it normal for these engines to need full choke for hot restart? I haven't had the car long enough to know what's normal yet. If it's not normal, can anyone suggest what the problem might be?
    Pete
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Cathy S.
    • August 31, 2003
    • 293
    Re: 1954 hot restart needs full choke -- what is normal?
    If mine sits for more than 15-20 minutes I use my choke also. Starts right up. Each car is a little different. You just have to learn your vehicle.
    • Jim L.
      • September 30, 1979
      • 1817
      A hot or even a warm re-start of my '54 involves just turning the key. Engine re-fires instantly.
      If I even look at the accelerator pedal or contemplate pulling the choke first, I'll be there for hours trying to get the engine started.
      I agree with the sentiment that each one is different. Do what works for you.
      Jim
      • Peter R.
        • June 19, 2011
        • 233
        Thanks for the input, Cathy and Jim. Looks like my car is not outside the range of "normal." I guess I'm learning its quirks.
        Pete
        Pete
        1954 Corvette #814
        • Tim E.
          • April 1, 1993
          • 360
          Pete - Does your starter motor seem to be turning the engine over normally when it's hot? 6v systems depend on a good ground to perform well. Search the archives for a past discussion on 6v starter motor performance and a properly gauged negative battery cable. The thread contains the part number of a NAPA cable that has solved many slow crank problems (reproduction cables are too small a gauge). Tim
          • Jerry P.
            • September 30, 1989
            • 85
            Tim... can you post the link to the thread that discusses the 6 volt neg cable from NAPA... thanks jer
            • Peter R.
              • June 19, 2011
              • 233
              Tim, It was turning slowly at times, when hot. I attributed that to my battery not being fully charged, but I am using a repro braided ground cable and I can see how that might be part of the problem. I will look into that. Thanks for the tip.
              I found the thread about the NAPA cable in the archives. It is:
              https://www.forums.ncrs.org/showthre...ight=volt+napa
              The part number still works at NAPA and it is an insulated cable, rather than a braid, so it may not look correct, but perhaps it will flow the necessary current.
              Pete
              Pete
              1954 Corvette #814
              • Tim E.
                • April 1, 1993
                • 360
                Pete - Here's the link to an even earlier thread which has some good discussion on starters and cables:
                https://www.forums.ncrs.org/showthre...lt-battery-C-1
                My old tractor had a 6v system and I was experiencing the same issue as you....slow starter performance and full choke on restart. Once I got the starter performance corrected, the engine starts immediately in all conditions.
                Tim
                • Peter R.
                  • June 19, 2011
                  • 233
                  Thanks, Tim. That gives me hope. I'm already working on a heavier ground cable/braid.
                  Pete
                  Pete
                  1954 Corvette #814
                  • Brad H.
                    • August 12, 2007
                    • 724
                    Or you can go to a 8 volt(readjust volt. Reg.) battery for more juice, also help's horn's work better. Thank's.
                    • Troy P.
                      • February 1, 1989
                      • 1284
                      Plenty of NOS 6v negative cables still readily available. No need to buy one that doesn't look correct.
