Hydraulic clutch change fluid? - NCRS Discussion Boards
  • Steve R.
    Infrequent User
    • February 1, 1987
    • 1
    What is the easiest way to change the fluid for the hydraulic clutch?
  • Vinnie P.
    Editor NCRS Restorer Magazine
    • May 31, 1990
    • 1561
    Re: Hydraulic clutch change fluid?
    Steve, I purchased a commercial type plastic syringe at a local medical supply store to draw the fluid out. Then you replace the fluid in the reservoir and pump the clutch about 30 times and repeat the process until the fluid is clear/clean. (usually two or three more cycles) Takes about 10 minutes and works great.
    • Jim T.
      • March 1, 1993
      • 5351
      What Corvette year model was the first for a hydraulic clutch? 1984? A large capacity syringe is also available at my local farmers CO-OP.
        • 15583
        Steve,
        Everything you ever wanted to know about a C6:
        http://forums.corvetteforum.com/c6-c...questions.html
        Have fun reading all that.
        Brake fluid -- way down the above list --
        http://forums.corvetteforum.com/c6-c...al-issues.html
        I have a kit in a plastic box I carry in the back storage compartment of the 2008. Syringe, a can (yes, it is metal) of GM brake fluid, and some paper towels. I give tutorials on the Road tour. Easy to do at the end of the driving day. It only takes a couple of minutes, and the next day i get the 30 pushes of the pedal as we go down the road.
