72 Spagetti (Dash and counsel wiring harness) - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    72 wiring info requested !
    Does any one out there Have information as to how/where the main dash/interior/counsel wiring harness as it comes off the fuseblock lays in or is routed. Also the correct assembly of the HVAC and shift controls.
    If any photos are available would you be kind enough to send me a copy ( I am willing to pay for same ) or the name of a publication that I can get my hands on to research. I have misplaced or lost all the photos I took of my car as I was dissassembling. I am not finding anything in my limited library.
    Any help here would be GREATLY appreciated !!!!!
    Thanks a bunch !!!!
    Rey Stenhouse (26007 -- 72 LS 502 Coupe)
  • Monte M.
    • January 1, 1991
    • 687
    Re: 72 Spagetti (Dash and counsel wiring harness)
    Rey,
    Do you have a copy of the AIM. It should resolves all the questions you have asked in your post. If you do not have one, you can go to the NCRS store and buy one.
    Out of the many books that are out there, this is for sure the first one to buy for your car. The AIM is the Assembly Manual for the original assembly of the car and is an excellent source of information.
    If you want to PM me, I will look up how the main harness routes after it comes off the fuseblock and relay it to you.
    Monte
      • 15601
      Just as a informational note. When the wiring harness for the Instrument Panel (IP) was installed the bundle was warmed under lamps to make it more flexible. Be cautious not to overheat it.
      • Rey S.
        • April 1, 1995
        • 277
        Hi Terry
        Thanks for the tip -- It really works great and when it cools off it holds its shape.
        Rey
        72 LS-502
        • Rey S.
          • April 1, 1995
          • 277
          Hi Monte
          Yes I would like to have the info you refered to.
          Rey
          1972 LS-502 coupe
