"69 tri-power throttle cable - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I have a friend that has a '69 L-71 and he just found that the throttle cable is shot. He e-mailed me this:
    "The tri-power setup uses a different cable that is 1 inch shorter due to carb mounting and is not reproduced. I saw a NOS one on ebay for $450. Not good news. From what I have read, if I use the standard cable it may bind because of the kink caused by the longer length."
    Is this correct or is a reproduction availible somewhere?? Thanks for the help!!
  • Jack C.
    • September 30, 1992
    • 1090
    Re: "69 tri-power throttle cable
    I think you can give it a more sweeping dip behind the valve cover than the more direct route that the original one takes. I shouldn't bind.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Grahame M.
      • November 7, 2011
      • 225
      I have the longer one on my 427/400 and it works perfectly.
      Cheers
      Grahame
      69 427 Tri-Power 4 Speed
      Black on Black
        • 43219
        Lynn------
        Early 1969 with 3X2 used the longer cable although a different bracket was also used. All 1968's did, too.
        As far as I know, there is currently no reproduction available for the shorter cable. However, I could see this happening in the future------if they can reproduce the longer one, they can reproduce the shorter one.
        • Tom L.
          • October 17, 2006
          • 1439
          Thanks for the help, it's nice to hear that the availible cable is at least functional. I'll pass the info along.
