65 is DOA - NCRS Discussion Boards
65 is DOA
  • Brett K.
    Infrequent User
    • February 1, 1984
    • 5
    65 is DOA
    Hi Guys
    I was driving my 65 small block (non TI igniton) as I have for years, stopped at the local ice cream shop and when I went to leave I turned the key and ....nothing. Got it home...Good battery, had the starter checked..it's ok, even replaced the ignition switch! Checked for broken wires (it has telescopic column) , took the connection off the back of the fuse panel (in the engine compartment) to look for corrosion....Still Nothing ..not a sound. Any clues?
  • Michael M.
    • February 15, 2007
    • 455
    Re: 65 is DOA
    Have you checked your engine ground, battery ground, etc.?
    • Don H.
      • December 1, 1981
      • 1493
      Re: 65 is DOA
      Open the head lights and turn on, then try to start. Do the lights stay on or dim badly? Easy way to check if it is battery or starter / wiring. If it has AC, check the connections at the firewall (C-60'itis). Good luck, Don H.
      • Lyndon S.
        • April 30, 1988
        • 1027
        Re: 65 is DOA
        check your fuseable link some times they break close to the starter due to age
        • Dick W.
          • 10483
          Re: 65 is DOA
          No fusible link on 1965
          Dick Whittington
          • Mike F.
            • April 25, 2011
            • 668
            Re: 65 is DOA
            When you say nothing happened, do you mean "nothing" as in no headlights, no interior lights, no radio, no anything, as if there were no battery in the car?
            How did you check the battery? The most likely item to fail would be the battery. Have you tried sticking a battery from another vehicle in the vette to see what happens?
            • Brett K.
              Infrequent User
              • February 1, 1984
              • 5
              Re: 65 is DOA
              Thanks for responding guys
              When I say nothing I mean not a sound, as if no battery in the car. Checked the ground connection, and ran my volt meter across the battery...also put the charger on it for good measure..
              • William C.
                • May 31, 1975
                • 6037
                Re: 65 is DOA
                Do other electrical items function? Radio Lights etc?
                Bill Clupper #618
                • Mike F.
                  • April 25, 2011
                  • 668
                  Re: 65 is DOA
                  Unless you had a bad buildup of corrosion on the battery terminal connections, sounds like the battery is DOA, shorted, etc.. Does the battery give off a scent of rotten eggs or sulfer? It's usually the simple things first.
                  • Brett K.
                    Infrequent User
                    • February 1, 1984
                    • 5
                    Re: 65 is DOA
                    Thanks again guys, no electrical items work....I did a battery test and it said it was fine, cleaned the terminals..etc.. I'll swap the battery anyway and see what happens...
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Re: 65 is DOA
                      I had this problem before. I would drive somewhere and go to start the car and it was dead...d-e-a-d. The plugs from the wiring harness to the fuse box were not making a good connection. This is a common problem on C2's. I would detect it by opening the door and looking at the courtesy lights. No lights, then the plug was loose.
                      Paul
                      • Lyndon S.
                        • April 30, 1988
                        • 1027
                        Re: 65 is DOA
                        my bad, C3 guy so I thought they had them in C2
                        • Jim L.
                          • September 30, 1979
                          • 1816
                          Re: 65 is DOA
                          Paul
                          Brett, I agree with Paul. It's a well known problem on C2s for the firewall connections to not make contact. I note that in your original post you said you checked this already. Still, I'd take another look before going to the trouble to change a battery that you say tests good.
                          Jim
                            Re: 65 is DOA
                            Brett -
                            Pay particular attention to the big red wire terminals inside the inboard (closest to the centerline) 8-way multiple connector on the fuse block; that's the main power feed from the starter solenoid for the whole car, and it's a common corrosion issue, which leaves the car dead as a stone.
                            • Brett K.
                              Infrequent User
                              • February 1, 1984
                              • 5
                              Re: 65 is DOA
                              Thanks Guys! I'll re-check the firewall connection before I do anything else
