1979 L48 Camshaft - NCRS Discussion Boards
1979 L48 Camshaft
  • Schanen C.
    • February 1, 2010
    • 122
    1979 L48 Camshaft
    Hi All,
    I need a new Camshaft.
    What is the correct Number for my L48 Engine ????
    And wich i can use in case i don`t find a NOS one,Brand etc.
    Thanks for all help.
    Carlo
  • Mike F.
    • April 25, 2011
    • 668
    Re: 1979 L48 Camshaft
    I believe this was the part # 3896929, now part # 12364051.
    If you need a cam (and I imagine other parts as well), it might be a good time "improve" on the performance while you have everything apart.
    What are your plans?
    • Joe R.
      • May 31, 2006
      • 1822
      Carlo,
      Now that Mike has kindly provided the GM #, you can go a couple of directions with that. You can search this board with it, which will probably turn up lots of threads with good info in case you might want to use a "better" cam. Or if you're sure that's the part you want to use, you can go to NAPA's web site, click the INTERCHANGE box, and do a search with the GM number. I came up with Sealed Power Part Number: SEP CS274
      I suspect that Sealed Power also has a cam and lifters kit, but I don't know the part number for that.
      Joe
      • Jim D.
        • 2884
        Joe
        The kit at Summit Racing is ZKC-274. Cam & lifters - $89.99
          • 43246
          Mike------
          It's not 12364051. The part number is GM #14060651
          • Mike F.
            • April 25, 2011
            • 668
            Mike------
            This is what the Google machine gave me for the #929 replacement,
            12364051 - Camshaft kit, Hydraulic
            "Dual pattern, blueprinted replacement for factory P/N 3896929 with 300 hp and 327 cu. in. camshaft.
            Technical Notes:
              • 43246
              Technical Notes:
              Mike------
              12364051 was a Crane-manufactured camshaft kit with lifters sold under a GM part number. It was discontinued a long while ago.
              • Schanen C.
                • February 1, 2010
                • 122
                Hi All,
                Thanks for All Answer.
                I plan to Rebuild my Engine to Original as Possible.
                I have found 2 Camshafts on Ebay with the #14060651
                Will Look also the Other Vendors.
                Brgds.
                Carlo
                • Larry B.
                  • October 21, 2012
                  • 71
                  That 274 NAPA or the sealed power or crane equal is the most wateredown broomstick they have it was listed for every stock small block to meet all emissions in all states.If you are rebuilding complete use the early stock flat top piston a consider a cam built you with 2013 technology done on CNC equipment.
                  • Mike F.
                    • April 25, 2011
                    • 668
                    If you are going to pull and rebuild the entire engine why not up the performance a bit? You could bump up the compression a bit, upgrade to the bigger valve heads, have the heads ported, use the L-82 camshaft, etc.. The engine will still look stock and make quite a bit more power.
