C3 Power Steering really too light - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12863
    Hi all,
    I have setup power steering on my car a couple of years ago but I noticed many time the steering is now way too light (and a bit nervous because of the lack of feedback). Is this common or something which can easily be adjusted?
    Rob.
    NCRS Software Developer
    • 6955
    Re: C3 Power Steering really too light
    Rob, The p/strg. control valve has a internal spring that senses the pressure from the pump, and this is what give the feed back to the driver. There is a letters stamp on the small cap on control valve that use to tell you the spring that was used.There maybe something up with spring. Broken? or compressed.
    • Paul J.
      • September 9, 2008
      • 2091
      Rob,
      Is this something that you have recently noticed, as if something has changed? Can you drive another one to compare? You may have a spring or valve issue, as Ed suggested. However, I've also heard from more than one of your Countrymen that the steering on American cars is way to light. I always thought that these complaints came from being accustomed to more "effort" in the power steering in European cars, as well as rack & pinion systems.
      Paul
