Instructions on how to make a starter switch for engine on chassis - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    I am wanting to make a starter switch so I can crank my engine for the first time before I set the body back on the chassis. Can anyone give me instructions on how to do so?
  • Jerry W.
    • January 27, 2009
    • 588
    Re: Instructions on how to make a starter switch for engine on chassis
    See attached
    • Jim L.
      • September 30, 1979
      • 1817
      If all you want to do is spin the starter, connect a momentary contact switch between the large starter solenoid terminal and the small, inboard (closest to the block) solenoid terminal. Activating the switch will activate the starter.
      Jim
      • Jerry W.
        • January 27, 2009
        • 588
        Justin....Before starting engine you should pump up the oil pressure....our engine guy had a special shaft for the distributor hole that fit his air ratchet gun
        I've seen people do it with a long screw driver...make sure you have a plug in the hole for the oil pressure line.
          • 6955
          Justin, As Jim says thats the easiest way, I just use a good old fashion manuel black push button. most auto parts store sell them. add a couple of wires with alligator style clips.
          • Justin B.
            • March 1, 1996
            • 478
            Jim
            Jim, I am wanting to run the engine for the first time...it is on the chassis and the body hasn't been put on it yet
            • Jim L.
              • 1817
              You'll need a second switch. Wire one terminal of the 2nd switch to the large solenoid post. Wire the other switch terminal to one terminal of a ballast resistor, securely mounted somehow. Wire the other ballast resistor terminal to the (+) terminal on the coil.
              Jim
