Valve cover ground strap bolts...head markings - NCRS Discussion Boards
  • Doug J.
    • April 1, 2005
    • 140
    Could someone please tell me what the correct, most commonly seen, or possibly/commonly used, head markings are used on the 4 bolts that hold the ground straps to the valve covers on the braided wires. Car in question is a 1971 with a 454.
    Thank you for any help,
    Doug
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: Valve cover ground strap bolts...head markings
    Mine are as shown......
    • Bob D.
      NCRS Shipping Data Report Manager
      • April 30, 1996
      • 793
      Doug
      The ones I have seen the most are the TR bolts, as pictured in Kevin's post, used for the spark plug ground straps. My '71 big block had the same bolt markings on the groud straps.
      Bob
      • Doug J.
        • April 1, 2005
        • 140
        Kevin and Bob,
        I have plenty of TR bolts for the straps. All the others are RBW, I'm hoping that they are correct? I recieved a deduct for having 4 SBC bolts with hardening marks last time, stating that A or C would be expected. Just trying not to make the same mistake twice.
        Thanks for your responses,
        Doug
        • Mike E.
          • February 28, 1975
          • 5141
          Interesting. Why grade 8 bolts for an application like that? Curious
          • Doug J.
            • April 1, 2005
            • 140
            Mike,
            I'm a little confused....where is there a grade 8 bolt?
            • Ron G.
              • December 1, 1984
              • 865
              Those TR bolts on Kevin's car are not grade 8, they are grade 5. Although RBW would not be ruled out as it is part of the GM family of hardware, I would go with the TR bolts as: a) they are the most commonly seen and B) I know Mr. Goodman's car original and is factory correct.
              "SOLID LIFTERS MATTER"
              • Doug J.
                • April 1, 2005
                • 140
                Ron,
                That's what I was confused about, the picture is of a grade 5 bolt! I have RBW bolts on all the other places, and on the 4 places for the ground straps I used the TR bolts. I'm hoping that should be good.
                Thanks......Doug
                • Mike E.
                  • February 28, 1975
                  • 5141
                  Right-grade 5. Grade 8 would have more striations. My bad.
                  • Dick W.
                    • 10483
                    3 lines=5
                    5 lines=8
                    Dick Whittington
                      • 15621
                      Not only do those big blocks need 7 bolts per rocker cover, they have to be grade 5 or 8 too! Heavy metal.
                        3 lines=5
                        5 lines=8
                        Dick -
                        6 lines = Grade 8
                          • 15621
                          Dick -
                          6 lines = Grade 8
                          Dick is having a Terry day too.
                          • Kevin G.
                            • February 1, 2005
                            • 1076
                            To keep it interesting, here's one from the other side.
                            • Doug J.
                              • April 1, 2005
                              • 140
                              Ron, So it would be safe to say that using the grade 5 TR head marking bolts for the ground wires and the RBW head marking bolts for the others would be a safe bet? The RBW bolts have no grade markings..is that correct?
                              Thanks again.....Doug
