Wheel well rubber undercoating; 67' - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Did the wheel wells originally have rubber undercoating? My 67 appears to have undercoating in the wheel wells; however, not the entire wheel well. What is the best way to gets this off? I was thinking a heat gun and scrape it off.
    Dave
  • Craig O.
    • July 31, 1983
    • 207
    Re: Wheel well rubber undercoating; 67'
    ck your 67 technical information manual & judging guide for a full explanation
    • Gary B.
      • February 1, 1997
      • 7019
      Dave,
      I believe the undercoating was placed there by the factory primarily in line with the width of the tire to protect the underside of the fiberglass from kicked up rocked, with the purpose of preventing cracks in the body paint on the top side. Why do you want to remove the undercoating? The original undercoating is on my '66 and I just want to freshen it up since it has taken on a lighter gray hue in spots after I cleaned off the grime and dirt.
      Gary
      • Dave K.
        • January 24, 2013
        • 278
        Gary,
        I'm doing a frame off restoration. Not sure the media blast guy will try to get it off, for fear of being too aggressive?? Thought I would try myself. If there's a getter approach I'm all ears. This is my first time restoring a car so I rely heavily on this website and reading material. I'm still struggling between media blasting and soda blasting.
        Dave
        • Gary B.
          • February 1, 1997
          • 7019
          Dave,
          I'm doing a frame-off on my '66 as well. For cleaning areas like that I start with Simple Green or something gentle, before progressing to things like acetone or a heat gun and scraper. But I'm definitely not going to remove that undercoating since it has the texture and coverage exactly like the factory did it, because the factory did do it. I just want to make it look dark gray or black again, rather than the lighter gray that parts of it took on from my cleaning.
          Why does the media blast guy have to remove the undercoating, unless it's not original? I don't see the need to get down to bare fiberglass under there, presuming you can restore what is already there.
          Gary
          • Monte M.
            • January 1, 1991
            • 687
            Dave,
            I used a heat gun, as you are thinking of doing, and scraped it off the best I could. Then, I used a plastic bristle brush to loosen up what else I could and then got ready for the messy part.
            I got a roll of paper towels and some acetone. Soak a half of paper towel in acetone and as soon as the undercoating loosen up, wipe it with a clean paper towel.
            If you just keep rubbing with the first towel, all you will do is smear it around and get it deeper in the glass.
            This method actually cleaned it up to the point you could not tell it was even there after hitting the fiberglass with some light sandpaper.
            Best thing to do is: do a small spot to make sure the results are satisfactory to you. It takes a little time, but it actually goes pretty good once you get the hang of it.
            Best of luck,
            Let me know how it works for you,
            Monte
            • Timothy B.
              • April 30, 1983
              • 5186
              Originally posted by Gary Beaupre (28818)
              Dave,
              Gary
              I agree with Gary, why do you want to remove the factory undercoating? Have you considered chemical stripping the paint just doing a small piece at a time.
              • Alan D.
                • January 1, 2005
                • 2038
                And I'll third that! Leave the original undercoating (assume its original).
                If you remove then the next step will be trying to find out how much undercoating needs to be put on again.
                If the color is a little light from aging there are other ways to get it back.
                • Page C.
                  • February 1, 1979
                  • 802
                  The original undercoating is very hard to duplicate. Years ago I would have done as others have suggested on ways to remove it, but now I would just clean the wheel wells and leave the original undercoating.
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    Dave I have removed my 68's and 70's Corvette's original paint using a chemical stripper, did not even consider blasting the paint off. Used Captain Lee's Spray-Strip 1-800-421-9498 or 615-883-5707. The spray-strip only removed the color coat of paint and left the factory primer which was easily wet sanded off to bare fiberglass with non-aggressive sand paper. Took my time and only did one section at a time. One convertible and one coupe.
                    • Gary B.
                      • February 1, 1997
                      • 7019
                      Alan,
                      What do people use to return the color to near black? The color on mine is definitely lighter gray, especially on the min-peaks of the mountainous texture.
                      Gary
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Alan,
                        Gary
                        Gary, the original undercoating should have been asphaltic based. Asphalt consists of oils, resins, and bitumen. Ever noticed how a freshly paved black road becomes gray over time? This is mainly because the oils have oxidized and became resins and the resins are also becoming dry and hard. If you replce the oils, it would turn black again. There are methods of taking a rapid cure asphalt and greatly thinning it so it is not viscous and flows very well. This technique is used to seal cracks in roads.
                        If you can find an asphalt roofing cement without fiberglass in it or an asphalt truck bed coating or an asphalt automotive undercoating, you can thin this with petroleum solvents to spray or brush on your old undercoating. This should rejuvenate it, but you have to put it on very thin and I don't know how long it will last. You may even be able to find an asphalt driveway crack sealer at the home center. While it's worthless for filling cracks, it would be easier to thin down.
                        Paul
