Drive shaft detail - NCRS Discussion Boards
Drive shaft detail
  • Michael J.
    • January 27, 2009
    • 7121
    Drive shaft detail
    On the '67 L71, I am not clear from reading the manual on the driveshaft finish and if any stripes are on it. Thanks for any opinions.
    Re: Drive shaft detail
    Michael -
    Finish is "natural", and a green and an orange stripe are typical.
    • Michael J.
      • January 27, 2009
      • 7121
      Thanks John. So I guess like the half shafts on finish, natural forged finish unpainted steel tube? And is the green and orange stripes, green toward the front and orange toward the back? Thanks.
      • Craig O.
        • July 31, 1983
        • 207
        here is one I restored
        • Michael J.
          • January 27, 2009
          • 7121
          Wow! Thanks, perfect. But please orient me, which end is front?
          • Craig O.
            • July 31, 1983
            • 207
            well, mine had strips to the front with green swatch to match pinion paint
            • Alan D.
              • January 1, 2005
              • 2038
              Of the 30 or so C2s I've seen all had strips to the front (at transmission) except one 63 shaft just to prove us wrong.
              Just my opinion - the Finish shown above is much to good, like it, but GM did not buff those tubes. So that can cut down on your work.
              • Michael J.
                • January 27, 2009
                • 7121
                Thanks to all for your help. And I probably won't buff mine so shiny. But, considering the driveshaft and half shafts were just bare steel tubes, the rust must have been horrendous over the years in bad places like the NE and Midwest. No wonder so many painted them in later years.
                • Timothy B.
                  • April 30, 1983
                  • 5186
                  Michael,
                  You are so right about the corrosion on these parts. Last year I replaced the drive shaft u-joints on my 67 and I could not in my right mind re-use that driveshaft. Places like Corvette's at Carlisle are good places to find a used driveshaft fairly cheep. After I glassbeaded the replacement shaft I used some chrome paint sprayed on a rag wet with acetone and rubbed a small amount on the shaft then polished with some fine steel wool. It looks just fine.
                  • Bill H.
                    • August 8, 2011
                    • 439
                    My 67 showing the swatch Craig mentions. My stripes were to the rear, not the usual but happens.
