alternator - NCRS Discussion Boards
alternator
  • Lyndon S.
    • April 30, 1988
    • 1027
    alternator
    Does anyone restore C 4 alternators.?
    • 6955
    Re: alternator
    Lyndon, I would do a search of your area for a local rebuilder. whats gone? bearing?
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: alternator
      looks like the front bearing is going out
        • 6955
        Re: alternator
        That is a common issue on those alternators front and rear bearings.- If you want to have the bearings replaced find a local guy, They generally stock parts for those alternators. If youe looking to preserve the original becareful of the numbers stamp. blasting the housing may remove the numbers. You may just want to keep the housing as is and tell the rebuilder that.
        • Lyndon S.
          • April 30, 1988
          • 1027
          Re: alternator
          thanks guys for all the info,does anyone reskin these alternators so the case would look new?
