Firewall Sealer - 1966 Corvette - NCRS Discussion Boards
  • Dane H.
    Infrequent User
    • February 1, 1989
    • 2
    I am finishing the restoration on my 1966 Corvette and need to apply sealer around the outer heater box cover and other firewall locations as applied at the factory. Can anyone share recommended products and methods to achieve the factory look and finish?
  • William F.
    • June 9, 2009
    • 1363
    Re: Firewall Sealer - 1966 Corvette
    3M makes the black pliable rods that can be formed into place. Paragon and I think Corvette Centrals this product.
    • Michael M.
      • February 1, 1993
      • 604
      I always thought that this material was sprayed on. I have had great success with a product called Submarine Sealer Cooler Coating. It has refined asphalt and waterproofing oils in it to give a rubberized result. It is also the correct black color.
      • William F.
        • June 9, 2009
        • 1363
        If you're talking about sealer around the wiring harness plugs and similar locations, it's not sprayed on, it's the 3M stuff I mentioned.
          Actually, in production, those firewall grommet/penetration applications used a liquid reclaimed rubber sealant applied from a flow gun.
          • William F.
            • June 9, 2009
            • 1363
            John,
            Thanks for the straight skinny on how it was done at the factory,but isn't the 3M "dum dum" I mentioned the most accurate way of reproducing these seals, when restoring?Please correct if I'm wrong; I'm a firm believer that those posting,myself included, should do their best to give accurate information, not just "Don't know, but I think---
              John,
              William -
              The 3M "Strip-Calk" is used today for many sealing applications where a similar string sealer was used back in the day, but I don't recall the name offhand of the current 3M liquid sealer product that's similar to the 60's black sealant that was used on the firewall grommets. Wayne Womble probably has the name of the current 3M product.
              • Michael G.
                • January 1, 1997
                • 1251
                John,
                Somtimes Bill thats all we got brother......best guess, ya know.
                • Barry H.
                  • April 30, 1976
                  • 213
                  Dane, To duplicate the look of the black rubber/asphalt sealer I use an inexpensive black asphalt roof sealer caulking in a tube.
                  It is easy to use with a caulking gun, & can be wiped with kerosene, plus easy cleanup with same. In over 30 years & many Top Flights & a Duntov, I have never received a deduction for this compound. There are many places where Strip Caulk was used, but for most wiring grommets & heater box apps the asphalt type caulking was prevalent.
                  Barry Holmes
                  • Tom R.
                    • December 20, 2010
                    • 177
                    Kind of relevant I hope. I've used the 3M strip caulk to seal the inner door moisture barriers to the inner door panels. I believe the factory used something similar.
