what is the best way to mask part assemblies for plating? - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1114
    What method do platers use to mask part assemblies with areas not to be plated? Or what do folks do that is better? I'm going to be getting some radiator caps, hood support etc replated, as well as other things. I want to mask the radiator cap rivet and pressure plate and 4-tooth washers on the hood support.
  • Don H.
    • December 1, 1981
    • 1487
    Re: what is the best way to mask part assemblies for plating?
    I have covered Fuel Injection shafts with duck tape when sending out to plate the end of the shaft and they come back unplated - as I sent them. I would discuss it with the plater before sending. Don H.
    • Paul J.
      • September 9, 2008
      • 2091
      Ian, a long time ago one of the members of this forum was responding to a question about plating (Jerry Fuccillo?). Included in his response were some pictures where he had used a special tape to mask off parts. This must have been well over a year ago.
      Paul
      • Ian G.
        • September 3, 2007
        • 1114
        Found that post, but looks like he was just masking a shifter plate for painting...
        • Paul J.
          • September 9, 2008
          • 2091
          I could be wrong about it being Jerry, but the pictures that I'm thinking of were showing before and after shots of home plating and the masking tape had printing on it.
          • Joe M.
            • April 30, 1990
            • 1338
            I found a liquid latex product at Hobby Lobby called Masquepen. It is acid resistant when it sets up; at least resistant to hydrochloric acid (muriatic acid). It is applied from a small diameter nib attached to a squeeze bottle. It is not full proof as occasionally, the acid will works its way under the latex. When you are ready to remove it, roll your finger over it and it rolls up in a rubber ball.
            The platers I have used in the past, use duct tape where possible. That obviously won't work on the radiator cap rivet, the latex might.
              • 15596
              Ian -- one of my students works in the plating industry. I can ask him what the pros use, but Spring break (as it is called in these PC times) is here and our next class is April 6. If you can not wait until then I can email him, but I can get a better answer for you face-to-face.
              • Ian G.
                • September 3, 2007
                • 1114
                Thanks joe. I'll look for it!
                • Ian G.
                  • September 3, 2007
                  • 1114
                  Terry, I'd be interested in hearing back. I move at a snails pace anyway (new baby, demanding job, etc). I bought some watercolor masking fluid, which seems to be what Masquepen is. The stuff I bought was called "Grafix 4-1/2-Ounce Incredible White Mask Liquid Frisket" with applicator. I'll let folks know how it went on this thread later.
                  • Paul J.
                    • September 9, 2008
                    • 2091
                    Ian, yesterday I was watching an episode of "Celebrity Rides" that I had DVR'd and they were replating some of the parts for a Duesenberg. The plater used duct tape to mask off areas that he didn't want plated. It looked like good quality tape. The episode was the one where they were repairing the rot in the wooden top. If you're not familiar with this program, it is shown on the DIY network and features the restoration of a Duesenberg Town Car owned by Jay Leno and being restored by Randy Ema.
                    Paul
                    • Ian G.
                      • September 3, 2007
                      • 1114
                      I'll keep an eye out for that one! I really enjoy "American Restorer", though they don't really focus on cars. So looks like I'll use duct tape for the areas I can wrap easily, and the latex watercolor masking fluid for smaller spots like the rivet and 4-tooth washer on the hood support.
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        You can also use enamel paint and take it off with paint stripper after.
                          • 15596
                          I will ask him Saturday. Maybe we will get on the Forum together, depending on how complicated his answer is.
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17651
                            Heavy duty wax should work. Tested this years ago. Wax a part and Captain Lee's stripper wouldn't cut it. Not sure how it would respond to plating.
                            Gary
                            NCRS Texas Chapter
                            https://www.ncrstexas.org/
                              • 15596
                              Ian,
                              The name of the product you are looking for is called "Stop Off Tape" I am told duct tape is a FAIL for a commercial plater. Heat aned acid will destroy the adhesive in duct tape.
                              In Chicago Stop Off Tape is available from
                              The STUTZ Company
                              4450 W. Carroll Ave.
                              Chicago, IL 60624
                              Phone: 773.287.1068
                              Fax: 773.287.4303
                              Stutz Company is a high-volume manufacturer of chemical compounds and a distributor of chemical solutions for metal finishing & plating.
                              email: stutz1@mindspring.com
                              This place usually supplies plating shops and is not a retail operation, however I am told they will work with you if you call during normal business hours in the mid-west time zone.
                              They have two types of tape Chrome colored is for chrome (DUH!) and a red color for other plating processes.
                              An Internet search for Stop Off Tape reveals a Sequoia Manufacturering Company in Las Vegas that only makes these kinds of tapes. I have no experience with them, but you can try.
                              FWIW: My student did say "They are no cheap." Best of luck.
