Thanks again in advance of all your help:
First the preliminaries.
1) gauge cluster done and bench tested in my presence before dinner by good friend Bill Harrison.... Great seafood place... Thanks Bill!
2) interior gutted and new lectric limited wiring harness, dynamat etc.
3) installed bench tested gauge cluster w/o steering column in.
4) finally hooked up battery with fire extinguisher ready...... No issues
5) BTW have all wiring diagrams, dr. Rebuild schematics, AIM etc .... Every recommended book and followed to the letter.
What works in first power up: without steering column in
A) starts and runs like a champ
b) all courtesy lights works perfectly as does door switches
C) head lights works as do high beams and door freely rotate up to open. Dash warning light flashes as headlight door opens.
D) oil pressure gauge works
E) radio works and lights in radio work
F) clock works and lights up
G) tach works
H) heater fan blows hard
WHAT DOESN'T WORK:
1) I now have no brake lights ( I did with old harness!!)
2) temp gauge pegs to right
3) no parking brake warning light
4) no dash lights (except clock)
5) full gauge pegs over full ( to the right)
6) when I turn on ignition both turn signal lights on dash turn on as does high beam indicator light.
I believe I have gauge cluster ground plug attached at top of cluster nd z bar ground wire near radio is good.
Is the fact steering column is not in yet causing these issues?
Wanted to check for issues before buttoning up and installing rebuilt column.
Any help on this is appreciated. I can post any picture requests that may help solve this...
Thanks in advance!!!!!
Keeks
G) tach works
WHAT DOESN'T WORK:
Keeks
