57 fuelie under heavy acceleration there is a grinding/vibration noise. Only occurs with heavy acceleration. There is no evidence of anything rubbing or hitting anywhere. Would appreciate any ideas anyone may have.
Drive line grinding/vibration
Re: Drive line grinding/vibration
Harold have you looked the drive shaft U-joints? They will cause a driveline vibration under accel and make a grinding type noise when the internal needle type bearings inside the cups loose there lubrication, They will start to get chewed up in quick order.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
if the u-joint's zerk fitting(or just the plateau cast for a zerk) was incorrectly installed so that the zerk fitting is in close proximity to the pinion shaft, it may be bottoming out on the pinion shaft under accelleration. the plateau should face towards the front of the car, not the differential. mike- Top
Do you feel the vibration through the steering wheel or the seat? If it's through the steering wheel then it's your tie rod ends. If it's through the seat then it can be u-joints, an axle bearing, something in the rear end, or even a motor mount.
Paul- Top
Harold,
U joints fail slowly. When they are so loose that the bearings are about to fall out, they will vibrate a lot at speed. However, when they just starting to fail they will squeak. If you roll the car slowly beside of a wall (preferably masonry) at 3-5 mph you can hear the noise. It will go "squeak squeak squeak..." rapidly.
Paul- Top
