68 TI harness routing thru firewall - NCRS Discussion Boards
  • Robert M.
    • January 1, 1992
    • 78
    I'm in the process of installing the wiring in my 68 and not sure where the TI extension harness goes thru the firewall, the Aim isn't real clear, can someone help me out with this?
    Thanks,Bob
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 68 TI harness routing thru firewall
    Bob. I believe the harness doesn't go through the firewall. The white cloth wire passes through the same gommet as the tach cable to enter the cockpit on the drivers side.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Terry B.
      • August 31, 1999
      • 607
      Jack,
      I think you are thinking of the wrong wiring harness. Remember the harness connects the TI box which is located at the driver side corner under the front fender. I believe the TI harness goes throught the same hole as the front wiring harness and fiber optics.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • Jack C.
        • 1090
        I think Bob is looking at the coil end and not the amplifier end of the harness. The wire through the firewall connects to the ignition switch.
        Jack Corso
        • Terry B.
          • August 31, 1999
          • 607
          Sorry Jack, I misread the request.
          Terry Buchanan
          Corvettes Owned:
          1977 Coupe
          • Robert M.
            • January 1, 1992
            • 78
            Jack is correct; I was referring to the coild end where it passes thru the firewall.
            Thanks for the responses. Bob
