Looking for an old Restorer article - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    I cannot locate my copy of The Corvette Restorer Index, and I need to find out what issue of The Restorer an article appeared in. The article was entitled something like "And the Numbers Match", or something like that. The focus of the article was a compilation of factory mistakes when stamping engine, transmission, frame numbers. The article featured missing characters, upside down characters, additional characters in the VIN and / or engine code stamps on various Corvette components.
    Can anyone identify the issue of The Restorer that this article appeared in?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Re: Looking for an old Restorer article
    Ed,
    The Restorer search page has a few categories that may help......
    Unfortunately you cannot enter a search string like "And the Numbers Match". You have to specify the category and year. I tried a few combinations but no luck using your title, however, Winter 1996 shows a article about Factory Engine pad Regrinds.
    A handy feature would be to allow the search to list ALL articles so you could import to a file and search separately.
    examples.......
    Your search results for: Engine Codes, 1963
    Issue
    The Ethics Of Engine Restamping Spring 1982
    Flint Engine Stamping Fall 1992
    Looking At Engine Pads From A New Angle Fall 1994
    The More We Learn Fall 1994
    Real Life 1963-67 Engine Pads Spring 1995
    Factory Engine Pad Regrinds Winter 1996
    Your search results for: Engine Codes, 1972
    Issue
    Origin Of The Zr-1 Code Winter 1990
    Mark Iv Engine Block Dates Summer 1991
    M Was For Mystery Spring 2001
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Ed,
      Tip, iIf you have the older Restorer DVD version, you can go to the DVD, don't start it, go to the Data folder, then open the Print folder.
      The Print folder contains all the Restorer text (.txt) files. You can search the text file from the Print folder.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Edward M.
        • November 1, 1985
        • 1922
        Don't have the DVD. I am hoping someone remembers the article. I'll keep digging.
        • Loren L.
          • April 30, 1976
          • 4104
          Try the word "anomalies" in the title - it might have been a John Amgwert column, not an article.
          • John N.
            • February 1, 1975
            • 451
            Loren-By memory John had a picture of a pad with anomalie stamp either on the cover or in the article. It was used as a FI test motor by the FI gentleman from Arizona.
            • Dick W.
              • 10483
              Vinnie, I think the story he's is looking for is one that the "Squirt" did in the early? '90's
              Dick Whittington
              • Vinnie P.
                Editor NCRS Restorer Magazine
                • May 31, 1990
                • 1584
                Ed advised those were not the articles he was interested in so I'm taking them down...however I think we might have hit paydirt with this one...
                From Volume 15 #4, Spring 1989
                Vinnie
                Last edited by Vinnie P.; March 24, 2013, 09:40 AM. Reason: added volume & issue #
