I need an education on a water pump and pulley.
I have a 1970 L46 (350/350HP), with Power Steering, no A/C, no A.I.R.. The "installed" water pump has been rebuilt twice in the last 30 miles or so, and the pump shaft is loose again. As RPM increases above 3000rpm you can see the fan assembly/water pump pulley start to wobble.
Not sure if it's the rebuilders fault, the pump is past the point of a decent rebuild, or the pulley/fan/clutch assembly is out of round/balance and wiping out the water pump bearing.
So I'm starting from scratch and ordered a water pump from Bill Mock (NCRS #93). He informed me that 1969 & 70 Corvette water pumps have an eight hole flange. (My current installed water pump has four.) Any particular reason for the eight holes?
Started searching for a two groove pulley (P/N 3890419) which most descriptions list as a 66, 67, 68 327 water pump pulley. I then called Paragon and Corvette World to ask a few questions, neither of their catalogues list a pulley for a 70 350/350. Neither could answer why they don't carry a pulley or what it should be. They both are going to get back to me when they find an answer.
So, what pulley do I need? Should the pulley have eight holes to match the water pump flange? Should the fan have eight holes to match up?
Any ideas on best way to check my fan for balance, alignment, etc.?
TIA,
Mike
TIA,
Mike
