1972 gas tank cap - NCRS Discussion Boards
1972 gas tank cap
  • Jerome P.
    • October 22, 2006
    • 607
    1972 gas tank cap
    Does anyone know where I can get an original cap for my 1972? Preferable in very good to excellent condition?
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1972 gas tank cap
    Jerry
    Here is one the Bay.
      • 43219
      Jerry-----
      1972 used the GM #3994339 gas cap. This cap is still available from GM for a list price of about 45 bucks. If there are any differences from the original cap, I don't know what they are. However, it may be that the Stant Manufacturing logo is a bit different.
      • Jerome P.
        • October 22, 2006
        • 607
        Paul/Joe, The local Chevy dealer can get one for me by tomorrow. I know the '72 has "OPEN SLOWLY CAUTION" and "SEALED" embossed into the topside of the cap and the sides are smooth vs scalloped.
        What I am not sure of is the design of the original SMC logo. From memory - I think the eBay item has the correct original logo. Your thoughts.
          • 43219
          Jerry------
          The current GM piece will almost certainly have the modern-day SMC logo. Otherwise, I believe it's identical to the original cap.
          • Paul O.
            • August 31, 1990
            • 1716
            Jerry
            As Joe stated the current will just have a large "S" only. The one on ebay has the original style the SM then a large "C" encircling the first 2 letters then it is all inside a full circle or ring for Stant Manufacturing Corporation if I recall correctly.
              • 6942
              I have seen the replacement caps they are shaped the same, but the plating in not silver Zinc as the one on E/bay , it is gold diachromate and the smc logo is different.
                • 43219
                Edward------
                The eBay cap has the dichromate (gold) over-plate. I don't know if the originals had this finish, or not. In any event, it's easy to remove. Just immerse the cap in a weak acid solution. This has to be done carefully, though, or one will blacken the underlying zinc plating.
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Ed
                  At some point in 1972 production or it could be most or all the gas caps had a Dichromate wash finish. That style was used till the introduction of unleaded fuels change the cap.
