1970 Horn Mounting? - NCRS Discussion Boards
1970 Horn Mounting?
  • Siegfried K.
    • November 23, 2011
    • 29
    1970 Horn Mounting?
    I am mounting the new GM reproduction horns on my 70, but I am unsure of how the passenger side mounts. The drivers side is quite obvious with the mounting tang locating hole, but on the passenger side I am unsure. The car had only one horn mounted when I purchased it. Would anyone have a good picture of exactly how the passenger side horn mounts?
  • Bob I.
    • November 9, 2006
    • 265
    Re: 1970 Horn Mounting?
    Siegfried
    On my 1970, the the passenger side is symmetrical to the driver side from the center of the car.
    Bob
    • Jim T.
      • March 1, 1993
      • 5351
      Unable to give a picture. The passenger side horn on my 1970 is located just behind the vacuum relay looking from the front towards the radiator/condensor.
      • Mike F.
        • April 25, 2011
        • 668
        Here's my 70.
        • Siegfried K.
          • November 23, 2011
          • 29
          Thank you for the pictures Mike. They mount as I presumed, however, beside the threaded hold on the passenger side, there is no pilot hole for the bent tang on the horn bracket, but the drivers side has the hole for the tang. Could the nose support bar have been replaced with a newer style one at one time? I have read the 71 and 72 year models only had one horn, maybe the pilot hole was not there on the passenger side on a service replacement part?
            • 15616
            Siegfried, the bolded sentence would be my guess. It was 1972 that got the single horn. 1971 had dual horns. At some time later in the C3 era the second horn became an extra cost option.
            • Paul O.
              • August 31, 1990
              • 1716
              1971 single horn well at least by my old Sept 70 build. P/N 9000245.
                • 15616
                1971 single horn well at least by my old Sept 71 build. P/N 9000245.
                Really, I guess I better stay away from Exterior and Ops -- or get out and do them to brush up.
                • Don L.
                  • August 31, 2005
                  • 1005
                  Hi Paul. Did you mean Sept '70 instead of Sept '71? My model year 1972 is a late August '71 build with a later VIN than 245 . I'm sooo confused...
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    Don
                    Good catch thats what I get for doing this late at night I have changed it thanks.
                    • Don L.
                      • August 31, 2005
                      • 1005
                      Don
                      Good to hear. I was MUCH more worried about me than you...
                      Don Lowe
                      NCRS #44382
                      Carolinas Chapter
