57 Radio - NCRS Discussion Boards
57 Radio
  • Tony P.
    • December 11, 2008
    • 84
    57 Radio
    Dumb question,Were is the antenna hook up on my radio.I hooked it up and its searching for a station.Is it the hole on the right side
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 57 Radio
    Yes, the hole is on the right side of the radio.
    If it does not pull in a station adjust the antenna trim screw on the bottom of the radio.
    • Tony P.
      • December 11, 2008
      • 84
      Re: 57 Radio
      Thanks,nice to know about the adjustment screw!!
      • Bruce B.
        • May 31, 1996
        • 2930
        Re: 57 Radio
        Tony,
        When you are ready to try the radio remember to do the following:
        Let the radio warm up for a while.
        Make sure the antenna is all the way up.
        Adjust the antenna trim, usually on a station about 1 to 1.5 inches from the right end of the station dial.
        Enjoy your radio.
        Bruce B
        • Tony P.
          • December 11, 2008
          • 84
          Re: 57 Radio
          Tony,
          Enjoy your radio.
          Bruce B
          Thanks so much for your help!!!1
