Re: 1966 ground strap questions
Hi Alan,
I purchased this as a project previously started by another - So I am not sure about the frame - but it looks either new or completely redone - neither hole appears to have been tapped - at least I could not feel any ridges or grooves with a bent paper clip end. Are all of the screws the same? If so I can get the motor mount connected up as I have a screw for the antenna ground strap and could use that one. The other areas are so easy to get at that they can wait. Right now I would like to get this one attached and install the exhaust system and get out from under the car. If the screws are different then I will just have to wait.
Joe
PS:Timothy was being kind when he said you would have to "struggle" with the power steering bracket.
Joe
Hi Alan,
Joe
Joe
