How do you remove the rear wire harness from a C2 convertible?
Rear harness removal
Re: Rear harness removal
Pull up the carpet on the drivers side rear wheel well to gain access to that portion, remove the fiberglass top hinge cover behind the seat, remove the sill plate on drivers side and pull down carpet to gain access in order to remove metal wire harness cover, pry that off. Disconnect the wires to tail lights, gas tank and backup lights. Here is the steel cover you have to remove.
wire.jpgLast edited by Scott M.; March 15, 2013, 02:44 PM.- Top
