67 427/400 AC car AC Vacuum Hose Routing - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 304
    Can anyone post a picture of 2 of the two vacuum lines that come out of the 4 hole firewall grommet and run to the right side manifold for vacuum source and for the hot water shut-off valve.
    Do they go high or low along the firewall behind the distributor (above or below the tach cable)? At what point do the break off the firewall and run to the engine and valve.
    The AIM UPC60 E6 shows a 327 for the source line and not much detail for the hot water shut-off line.
    Steve
    Steve Gansky
    Newtown, (Bucks County) PA
  • Stephen G.
    • January 1, 2002
    • 304
    Re: 67 427/400 AC car AC Vacuum Hose Routing
    Help help help... Still need hose routing..
    Steve Gansky
    • Gary C.
      • March 1, 1998
      • 236
      Hi Steve
      Hope this helps. This is how mine looks.
      Gary
      • Stephen G.
        • January 1, 2002
        • 304
        That's a big help....
        Steve
        Steve Gansky
        • Stephen G.
          • January 1, 2002
          • 304
          Gary
          Can you get me some shots of the lines as they exit the 4 hole grommet thru the firewall and then up and over?
          Steve
          Steve Gansky
