Took the trim off today - NCRS Discussion Boards
  • Jack P.
    • March 19, 2009
    • 1135
    Many of you have followed my travels in the US and Europe over the last 3 years. Last spring I had to replace the windshield that was hit by a stone near Park City UT.
    It was the 3rd windshield since car was new. I replaced original in 1976, could not see through (150,000 miles) on car, it lasted until 2012, about 150,000 miles.
    In my rush to get the car ready for the European trip, we put the windshield in and followed right away with the trim. In hindsight, not a good idea. Lots of sealer and glue and junk, you are in a hurry and the job did not come out looking good. No leaks , but I was ruff with taking it off, put some bends in it, did not get the front piece centered, etc.
    Well I got inspired by 65Rush (Jim) replacement and polish job on his trim.
    I called over a friend and in less then an hour we had it off. The biggest mistake I made , and maybe others that have problems putting trim on , is too much sealer when installing windshield. Over concern with sealing everything. (too much around clips) etc.
    Taking off trim is not hard, just have to do it in the right order. Take out every screw first that hold trim, latches, mirror etc. Trim screws, do not have to take off trim in front of pad.
    Take off inside piece first (mirror) part, next top piece after gently pulling side pieces away from cage. (4 5/16 speed nuts 2 reg nuts hold trim) You must take of side pillar rubber first and mounting plate for trim.
    You can then side out side pieces from front trim, next release the front trim with tool
    I will post tomorrow a few pictures of the tool in action. Most have problems because they do not understand how the tool works to release trim.
    Installation , have to wait until trim is done but....before putting trim on. I will talk about a order of installation later.
    It is important to make sure the clips are free of sealer so they can grab the trim around the front windshield. Also , I found the grove of the front trim to be clogged with gunk, gunk in the grove, keep the clip from locking in place.
    I am debating doing the polish myself, but don't feel good about it.
    I hope this helps some of the new members who may be thinking of doing this job
    Jack
    Pictures
    Trim off ready for repair and polish
    Birdcage too much sealer
    Before defects
  • Paul J.
    • September 9, 2008
    • 2091
    Re: Took the trim off today
    Jack,
    The trim has a flash plating on top of the stainless. You'll need to remove this plating before polishing and send it to a plater afterward to have it replated. No big deal, just another step.
    Paul
    • Jack P.
      • March 19, 2009
      • 1135
      I got home and unwrapped the polished trim. I will do a post on Back Bay Customs, a great mod-hot rod shop, that helped me out with polishing.
      I wanted to trial fit the trim. The front piece must be placed so that equal distance of ends are under side trim , for trim to fit in corners.
      I put on the top piece first, followed by the outer side trim only, with only one screw to hold it to birdcage loosely.
      I put one end of front trim into side piece to get right distance under trim. I clipped down 1/4 of front so I could mark trim and having marked windshield , I had a mid point to always line up front piece for later final fit.
      I had no trouble with clips catching as I cleaned out the space between rubber and front fiberglass, as stated in earlier post.
      There still is a slight problem in the corners , as the rubber does seem to bow out a bit, pushing the trim away from the body, the clips catch but there is a gap. I am not going to fix the rubber. no leaks in windshield. I will fill it with a flexible sealer.
      I hope this helps others in trim work. Total time to put trail fit about 1 hour. Should take about the same for final fit. It helps to have two people , one on each side to slide side pieces into place with front at same time. Or, if you start on one side as I did, get two or three clips to catch, then go middle an lock down center two clips , go back and finish one side and work your way to other side, stop about two clips from end, side in side piece with front, push together and down, screw in side piece , all should be clipped.
      Again, there must be enough space between rubber and fiberglass to push trim edge in far enough to catch clip. With new clips, get one to catch , look at it , and see how it catches. You must get it in same position alone the front for clips to grab trim. I have original clips , so it was lack of space , that would hinder clipping, not clips.
      Now I have to take it all off, side pieces first, slide them out from front trim, get first clip to release and off you go.
      I will post pictures of removal as I have to finish cleaning up excess sealer from the windshield install last year.
      • Jack P.
        • March 19, 2009
        • 1135
        I am continuing with engine bay clean up and maintenance. The hood has been repaired and painted. My heater motor, still works but has a loose bearing, and rattles when turned on. I had thought it was the fan hitting the enclosure, but after taking motor out and bench testing it, the motor itself rattles. I can move the shaft in and out about 1/8" or more.
        I have ordered a new motor as I don't believe you can take the motor apart. Only $29 from Zip Products for a new one. I will use the old fan as it is still in good shape.
        Even though I completed a restoration of the engine bay only 3 years ago, 50,000 miles will produce a little dirt and grime.
        On the trim, the photos show how I put on the front piece. It is very important to make sure the there is room under the rubber, to slip in trim. Soap and cleaning out all the sealer from windshield install will help.
        I should have the car back together in a few days.
        Motor Fan Overflow
        Trim need to find midpoint
        Job done
        Hood
        • Jack P.
          • March 19, 2009
          • 1135
          A magical moment !
          You walk around grumpy, nothing seems right, people will ask, whats wrong ?
          But we know what is wrong, and we have done something to fix it.
          But you have to wait, just a bit if you use the right vendor.
          And then it happens..you come down the driveway, afraid to look up....and then you do ....
          And then the magical moment ! You float out of the car and walk up to the door and there it is....
          In my case, Zip Products, new heater motor and other little goodies
