Rear Storage Compartment Rebuild (1968) - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    Does anyone out there rebuild the Rear Storage Compartment Assemblies? I have a 1968 with the springs so buying a 'Repo' assembly is not an option for originality. I have tried to install my hinges (with the springs) on a new frame but cannot get everything to fit properly. Thanks if you know of someone who can assist with a rebuild of my original. Maybe if you have had the same problem, you bought the 'Repro' and took the points deduction?
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Reba W.
    • 937
    Re: Rear Storage Compartment Rebuild (1968)
    All the repro hinges I have seen are stainless steel. You would lose for that finish plus the lasck of springs.
    • Jeffrey S.
      • May 31, 1988
      • 1882
      Bill,
      I have rebuilt my '69 (with springs) successfully. What doesn't sem to fit? Are you riveting the hinges onto the plastic? Tell us where the problem is and maybe I can help.
      Jeff
