67' Muncie 4 speed with cast #3851325 - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    I believe cast # 3851325 is a Muncie 4 speed for 1964 and early 1965....however, I have a 1967 427 convertible with this muncie 4 speed. Is this possible or do I not have the original Muncie in my car.
    Dave
  • John D.
    • June 30, 1991
    • 875
    Re: 67' Muncie 4 speed with cast #3851325
    dave
    Is there a VIN or assembly date stamped on the side of the case ?
    • Dave K.
      • January 24, 2013
      • 278
      Yes! Right below the #3851325 (on the right side) it says US Patent No. 3088336 GM corp...then to the left of that (at the rear of the tranny) it says PO819. Also at the top of the tranny it says K108366. Left side of tranny on the side cover it says 3884685.
      • William C.
        • May 31, 1975
        • 6037
        Simple, you have a 64-65 Trans in a '67 car...out of a car built at the Leeds, plant (Ks City) Probably an "A" body Chevelle, Olds Cutlass or Pontiac Tempest
        Bill Clupper #618
        • David L.
          • July 31, 1980
          • 3310
          Dave,
          The "3851325" casting number on the main case is 1964-1964 vintage. The "P0819" stamping is Muncie, August 19th. The "K108366" is a partial VIN where K = Kansas City. Chevelles were made in Kansas City but not Corvettes. The "3884685" side cover is 1966-1967 vintage.
          The 1967 and newer Muncies have a different stamped date code format.
          Example: "P7E03" = Muncie, 1967, May, 3rd day of month
          A = Jan., B = Feb., C = Mar., D = Apr., E = May, H = Jun., K = Jul., M = Aug., P = Sept., R = Oct., S = Nov., T = Dec.
          Is the tailshaft casting number "3846429" (until 2/65) or "3857584" (after 2/65)?
          Years ago I had a 1967 Corvette Muncie case with a "3885010" casting number and stamped date code "P7B137" (Muncie, 1967, Feb. 13th, with only the top half of the last number "7" which I no clue of its meaning except possibly a mistake). The partial VIN was "7S113122" where "S" = St. Louis. I bought the case at a swap meet in Taunton, MA, in June 1989.
          Dave
          • Dave K.
            • January 24, 2013
            • 278
            The tailshaft is 3857584. So this means i do not have the original tranny? The tailshaft however could be original??
            Dave
            • David L.
              • July 31, 1980
              • 3310
              Dave
              Dave,
              According to "1965-69 Chevrolet by the Numbers" the 3857584 tailshaft was used on 1965 models made after Feb. 1965. The production usually ends in August. The August 19th main case seems really late for a 1965 model but who knows. The side cover is 1966-1967 vintage.
              Obviously there were some changes made.
              Dave
              • Dave K.
                • January 24, 2013
                • 278
                Thx everyone! I knew something didn't add up when I referenced the Corvette ID Numbers catalog. I'm slightly disappointed because I thought I had a 67' vette with the original motor and tranny. On the inner door of the glove box are some stickers that have 1st and 2nd place finishes at a drag strip in Michigan from the early 70's......this probably explains what happened to the original tranny.
                • Mike E.
                  • June 24, 2012
                  • 920
                  I've seen two types of bosses on the top of a 3851325 cases. I've wondered when this changed?
                  Mike
                  • William C.
                    • May 31, 1975
                    • 6037
                    Some pictures from a '66-67 style muncie case and tail attached. Note speedo outlet on the pass side and "010" casting on the main case.
                    Bill Clupper #618
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      He has a very early '65 Muncie trans P0819 (assembled Aug 19th 1964) and (as you say) probably into a Chevelle produced about mid-Sept '64 (end of month Kansas City Chevelle VIN for Aug is 102623; and for Sept is 112784).
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        Mike -- your top photo has the rounded nose for the bolt boss, and was on '64 and '65 ...325 cases up to (about) early December 1964, after which it went to the square shape (stronger ?).
                        But your bottom photo is of a SERVICE ...325 case, cast in the ...660/661 case design era. Notice the wide stamp pad. Looks like there's an over-the-counter Muncie production 5-digit number stamped there. Reason why they continued to provide service ....325 cases is to accomodate the original ...325 7/8" dia. counter shaft and other minor internal features which couldn't transfer to a 660/661.
                        Mike
                        • Mike E.
                          • June 24, 2012
                          • 920
                          Wayne,
                          Thanks for clearing that up. Both of those cases are on Ebay right now. I just grabbed the images to ask the question.
                          Mike
                          • Tom D.
                            • September 30, 1981
                            • 2135
                            I wonder which Michigan drag-strip...
                            https://MichiganNCRS.org
                            Michigan Chapter
                            Tom Dingman
                            • Tom P.
                              • April 1, 1980
                              • 1815
                              Dave
                              There is no casting numbers on a tail shaft----------------------BUT, there MAY be a casting number on the tail housing.
