1954 water pump heater hose nipple - NCRS Discussion Boards
  • Peter R.
    • June 19, 2011
    • 233
    Please see attached picture. Is this what the original heater hose nipple on the six cylinder water pump should look like? It is 1-1/2" long. With this nipple, there is little to no room to install a Corbin clamp on the heater hose because it interferes with the lower radiator hose. I'm wondering if the original nipple might have been longer in order to get its clamping area out of the way of the radiator hose. Thanks for your help.
    Pete
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 water pump heater hose nipple
    I have never seen that nipple....
    Ones I have seen are longer......
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Eric F.
      • June 30, 2003
      • 319
      Pete, I've attached a photo that shows the one on the engine I am currently restoring. It is correct. EricHeater hose connections.jpg
      • Chris S.
        • January 1, 2000
        • 1068
        Yep - Eric's are the ones I have seen........
        • Peter R.
          • June 19, 2011
          • 233
          Thank you both, Eric and Chris, that's just what I needed.
          Pete
          Pete
          1954 Corvette #814
