Location of voltage regulator and horn relay 1964 factory air condition - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    I have tried to search for pictures showing if the volt regulator is sitting on the left inner fender or on the left side radiator support with not the best of luck
    I have seen 1965 and newer with the voltage regulator located on the left inner fender but i think the regulator are located on the radiator support on a 1963 and 64
    My car have the voltage regulator and horn relay located at the left side radiator support so i just want to be sure that it is on the right location
    Is there any here that have a picture showing the the voltage regulator and horn relay for a 1964 factory AC
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Location of voltage regulator and horn relay 1964 factory air condition
    Claus -- have you looked at Noland Adams 1964 section, page 218 ? There's a drawing which I assume is from the '64 AIM, which shows the volt reg on the left fender, using holes drilled at the existing dimples in the fiberglass, just like 1965 MY. Another note says to fill the corresponding 3 pre-drilled holes (for non-air cars) on the right fender with cement.
    • Claus S.
      • December 30, 2010
      • 414
      Hi Wayne
      Yes i have seen that picture.
      I have also seen a couple of pictures of 1965 and newer cars having the resistor located on the left inner fender but i think it is supposed to be located on the radiator support on a 1964
      It looks like that on 2 pictures but it is not easy to see because the pictures was of poor quality and almost did not show the resistor
      This is a picture of a 1963 but you cant see the voltage resistor(but it looks like it is placed on the radiator support since it is not shown on the left inner fender)
      • Joseph T.
        • March 1, 1986
        • 169
        Wayne,
        Picture of the Voltage Regulator and Horn Relay on photo.jpgan early 65 with AC. Not sure if 64's are the same.
        • Dan H.
          • July 31, 1977
          • 1372
          Claus, both were mounted on radiator support on 64 vin 8477.
          1964 Red FI Coupe, DUNTOV '09
          • Alan D.
            • January 1, 2005
            • 2054
            And that's on the right side for non AC cars. Although the AIM shows it mounted similar to a 65 - do not believe that change ever took place on even late 64's. Have seen some late 64's and mounting has always been on right radiator support. Do a search on regulator and you will find some good pictures. See 64 Ground - voltage reg to horn relay
            • Claus S.
              • December 30, 2010
              • 414
              Alan. Yes i know the voltage regulator and horn relay is mounted on the rights side for non AC cars
              I would think a factory AC car will have the voltage regulator and horn relay mounted like a non AC car and the only difference is that the factory AC car have it the voltage regulator and horn relay mounted
              on the left side on the radiator support
              The assembly manual shows the voltage regulator and horn relay mounted like on the picture posted by Joseph but i have not seen it like that on any pictures when doing a search
              for 1964 factory AC cars on the internet
              Dan. So having the voltage regulator and horn relay mounted on the left side radiator support is correct for my December 5`th 1963 built car?
              • Dan H.
                • July 31, 1977
                • 1372
                Yes, my AC 64 was built Jan 7, 64.
                • Claus S.
                  • December 30, 2010
                  • 414
                  The picture to the left is of a 1964 with factory AC
                  The picture to the right is from the assembly manual and shows the voltage regulator located on the left inner fender and i think the assembly manual is wrong since (it might be a change for late 1964)
                  the pictures i have seen of 1964 factory AC cars have the voltage regulator and horn relay located like on the left picture
                  • Wayne M.
                    • Mike G.
                      • Dan H.
                        • Alan D.
                          • Dan H.
                            • Dale M.
