I'm in the process of adding back on the ignition shielding that was supposed to be on my 66 327 with A/C. Trying to figure out how things go from the AIM, but I am having some trouble.
First, does the righthand side manifold have a french lock on the front two manifold bolts or in this case because of the A/C the frontmost bolt is replaced with a stud? Speaking of the stud, does one of the thick exhaust washers go under it? My current setup didn't have a washer or a french lock in that location.
Next, how do the shielding brackets that hold the front horizontal shield attach with the lower compressor support bracket also there?
