1966 A/T questions - NCRS Discussion Boards
1966 A/T questions
  • Joseph U.
    • April 30, 2001
    • 241
    1966 A/T questions
    I have moved on to the A/T connections for my 1966 base engine coup with A/C and have two questions (for now).
    1. I can't seem to find in the AIM how the speedometer cable is connected. I can see where it goes from transmission to speedometer on the manual T but not with the Automatic T.
    2. I purchased new cooler lines for the A/T several months ago and installed them to the A/T. There is a cap on one of the lines which I thought was there to keep the dirt out and I left it in place - went to connect to the small A/T "radiator" on the front today and as it turns out the "cap" is not plastic but metal (I have attached a picture). Does anyone know what this is. Want to check before I cut it off.
    Joe
  • William C.
    • May 31, 1975
    • 6037
    Re: 1966 A/T questions
    if you are talking about the line on the left, it is indeed a plastic cap...
    Bill Clupper #618
    • Joseph U.
      • April 30, 2001
      • 241
      Good, I will just cut it off. Just did not want to destroy it if it was something important.
      thanks for the help. BTW - it is very hard and I can't move it with my hand or a small screwdriver. Will try to cut it apart with a knife.
      joe
        Joe -
        The Powerglide and 3-speed manual use exactly the same speedo cable routing and clipping - see your A.I.M., UPC 12, sheet C3.
        • Joseph U.
          • April 30, 2001
          • 241
          Perfect John.
          As always thanks.
          Joe
