63-67 Fender Skirt Bolt Hole Measurement Needed - NCRS Discussion Boards
  • Monte M.
    • January 1, 1991
    • 687
    I need the measurements from the center of the bolts that hold the fender skirt to the radiator support to the top bolt of the lower hood support bracket. I am working on a 1963.
    Basically, the fender skirt was hit and torn between the radiator support braces and the lower hood support mounting bracket. If I have the two measurements from the radiator support bracket to the hood support bracket, it will locate the the two pieces in their correct place in reference to each other so it can be repaired and glassed back together.
    From the upper radiator support hole center to the upper hole center on the lower hood support bracket = Dimension "A"
    From the lower radiator support hole center to the upper hole center on the lower hood support bracket = Dimension "B"
    Thanks Guys
