C1 Trap Door Oil Pan Identification - NCRS Discussion Boards
  • Mark S.
    • January 26, 2013
    • 88
    Seeking your expert assistance. I have (2) C1 3-Step Trap Door Oil Pans and want to be certain to install the correct Oil Pan on my 1960 270hp car.
    Each Pan has the correct single long vertical crease line along with identical rivet marking locations for the side baffles and trap door.
    My questions are as follows:
    Your assistance is greatly appreciated. Thank you in advance.
  • David L.
    • July 31, 1980
    • 3310
    Re: C1 Trap Door Oil Pan Identification
    Mark,
    One pan might be GM # 3769761 (1960-1961 Corvette) and the other pan might be GM # 3789629 (1962 Corvette). In your 4th photo, the pan on the right side with the single "half moon" cutouts on the side baffles looks like the 3769761 oil pan.
    According to Chevrolet Parts History GM # 3769761 was replaced with GM # 3789629 in October 1961 for over the counter parts.
    I am not an expert on straight axle Corvette parts but I have done some research on Chevrolet oil pans over the years.
    The link below might be helpful if you can read it.
    Dave
    • David L.
      • July 31, 1980
      • 3310
      Mark,
      Listed below is a NOS 62 Corvette oil pan (GM # 3789629) currently on Ebay for those with really deep pockets.
      Dave
      • Bill M.
        • April 1, 1977
        • 1386
        My guess is that the two cut out areas for the '62 pan provide a better fit of the baffle to the pan body (for a more secure spot weld.)
        • Greg K.
          • September 30, 1985
          • 35
          From working with manufacturers, the baffle with the two cut outs could be left over parts for oil pans with two grooves used in the newer oil pans. Just a hunch.
          • Loren L.
            • April 30, 1976
            • 4104
            The one on the left gets my vote as the OEM 60-61 HP trap door. Both would probably pass judging.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Mark, On your left pictured pan in photo #4....
              Look very closely on the pan-to-block mating area on the left side(Drivers Side), between the 3rd and 4th attach bolt. There may be a date stamp visible. I have a service replacement on my '59 270hp. The date stamped on the pan's flange is 7 79. (July 1979). This one obviously not original.
              Below is what I believe is a original trapdoor pan which came with a '61 project. There is no date stamp on this pan.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11364
                I forgot...I took this one off of a 283 a few weeks ago. It's a replacement not original(I think). Painted black inside(not residue).
                IIRC there was a date on it too but that I don't recall. It has the 2 grooves on each side and the two half moons on the reinforcements to clear the grooves.
                ------V------------V
                • Bob J.
                  • December 1, 1977
                  • 720
                  I'm fairly certain the rectangular oil drain plug plate is period correct for C1 Corvettes. BobJ
                    • 43285
                    Originally posted by Mark Sollazo (57962)
                    Secondly, the Oil Drain Plug thread types differ as well.
                    Mark------
                    If you are talking about the thread size being different, then one of the pans must have had the oil drain re-threaded. All 1955-82 oil pan drains were 1/2-20 thread.
                    If you're talking about the drain flange or nut, I believe that original 1955-57 and 62-82 used the spot welded-in flange plate whereas original 58-61 used the welded-in nut. Later SERVICE pans for all 1956-82 applications used the spot welded in flange plate.
                    • Ian G.
                      • September 3, 2007
                      • 1138
                      I'm probably going out on a limb here, but after a lot of reading and examining ebay auctions and more reading, and getting the wrong pan and then finally what I think is the right pan for my early 59, here is what I think:
                      Rich's pan is an original 761, used late 60 to 61.
                      Mark's left photo appears as an early replacement 937 pan (it seems to have had two versions, same number with different weld spots, etc) (are a 629 as david suggests) and the right is an original 642 for 57 -60E like I have (which agrees with Bob's observation). From my understanding though, depending on "early" and late" 60, it could either be Rich's pan or that pan as "correct" on a 60. I don't know what early or late would be in terms of month though. I think it is a early 937 since that one has a lot of spots welds on the side, and that one appears to have them, though i can't tell with the paint.
                      My assumption on the extra cutouts on the 937 (or 629) is a cost-saving measure so the baffles could be used on other pans.
                      Please take what I think with a grain of salt.
                      • John R.
                        • November 1, 2005
                        • 433
                        Adding to this 6 year old post. Found what I think is a unique trap door pan, at least to me. Wondering if anyone else has seen this configuration?
                        It's a 2 side rib, 3 smooth step, rectangular oil plug plate pan with trap door. Thought trap doors were only supposed to have 1 rib? Has all the characteristics of a 57-59 pan, but with the trap door. Huh...?
