Left turn signal not flashing - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2418
    On my 62 the left turn signal has stopped flashing. All lights light up, brake lights work, right turn signal works. When I turn on the left signal, the front left and rear left light up but do not flash. I intend to get flight judged in Austin next month, and flight judged in Frisco at the Lone Star Regional for Star Bowtie signoff. I am trying not to mess with much due to a shot at Star Bowtie next year in Kansa City. Can I try to fix this problem w/o jeopardizing any points?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11356
    Re: Left turn signal not flashing
    John,
    Does the left dir Dash lamp light? If not, the reduced load may not be enough for the flasher to trip off/on.
    If you step on the brake does the left rear stay lit?
    • Bert L.
      • April 30, 1977
      • 427
      Looks as though you are experiencing some grounding problems......shouldn't be too difficult to rectify.
      • Joe M.
        • April 30, 1990
        • 1342
        When that happens on my 1960, it means a grounding issue. I will see you in Bee Cave next month, but won't be driving the 225 miles in the 1960.
        • Terry B.
          • December 6, 2010
          • 73
          I had exactly the same symptoms with my 62. Replaced the flasher and everything works. I'm not certain that they check the flasher during Bowtie but believe that they do as that was one thing that I know was checked when I had it inspected privately. If it is a bad flasher you'll need it to be functional for flight judging but may, as they don't tell exactly what they look for in Bowtie judging, need the original for Bowtie judging. I'm not sure about the legality of switching the flasher between judgings as mine failed after Bowtie judging so it wasn't an issue.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11356
            Yes, It could be a bad ground. That can do strange things.
            Since a 62 has 2 lamps per side, make sure you have the correct bulbs. Are both left lamps lit when not flashing?
            One other possibility.....I just noticed "similar threads" at bottom of page.....
            If the tail lamp socket harness connectors are reversed, it would change the load because the filaments of the bulbs would be reversed.
            https://www.forums.ncrs.org/showthre...e-on-left-side
            • Paul J.
              • September 9, 2008
              • 2091
              This is a classic symptom of a bad flasher. John, replace the flasher first and in the low likelyhood that it still continues, look for a bad ground.
              • John F.
                • March 23, 2008
                • 2418
                Has anyone taken a flasher apart? Can they be rebuilt internally? Mine is a Signal-Stat ZN332-12V. Any pictures of one apart?
                • John F.
                  • March 23, 2008
                  • 2418
                  Okay, curiosity got the best of me. I had to open it up. The ZN332-12V Signal-Stat flasher. Here are a few pics, but not sure what I am looking at.
                  • Joe M.
                    • April 30, 1990
                    • 1342
                    You can test the flasher by connecting it directly to a 12V battery with a couple of jumper wires. I tested my ZN 232 flasher that way and it worked. Do you have a ZN 332 or ZN 232?
                    • John F.
                      • March 23, 2008
                      • 2418
                      The picture is of a ZN332-12V.
                      • John F.
                        • March 23, 2008
                        • 2418
                        I took the flasher apart and cleaned the contact. Put back in and the right side blinks,but not the left. The left parking light and two rear left side come on,but do not blink. All brake lights work, headlights and taillights work. Parking lights work. Where would you start looking for a bad ground?
                        • Philip P.
                          • February 28, 2011
                          • 558
                          John
                          I would check the voltage at the lights with the left turn signal selected. It sounds like the load on the left is not correct may be in the turn signal switch. It may also be a bad connection in the rear between the 2 tail lamps. I do not know how they ground the housing but I would make sure they are all clean.
                          Phil
                          • Rob M.
                            NCRS IT Developer
                            • January 1, 2004
                            • 12844
                            just run a temp. jumper cable from the left taillight housing(s) to a reliable ground (bare metal on the frame) and check if that makes a difference...
                            Rob.
                            NCRS Software Developer
                            • John F.
                              • March 23, 2008
                              • 2418
                              I took the bulbs out front and back. They were GE 1034. I cleaned the sockets and contacts. Also found a loose wire in the front harness that crosses in front of the hood. Seem to work okay now. Thanks for all the help everyone!
