AIM databases - NCRS Discussion Boards
AIM databases
  • Donald O.
    • May 31, 1990
    • 1585
    Re: AIM databases
    Originally posted by Nicholas Leonardi (6022)
    Do you have the A.I.M. for 1960 corvette?
    Nicholas, et al
    See post #3 in this thread for a listing of the AIMs I have completed.
    Don
    • Greg W.
      • February 26, 2015
      • 141
      Re: AIM databases
      Don, This may be twice but could I get the AIM for 66 and agree to never sell or redistribute it in any way.
      welshroofing@Verizon.net Thanks Greg
      • Hugh G.
        • January 14, 2015
        • 64
        Re: AIM databases
        Donald,
        I agree to never sell, or redistribute the AIM database(s) in any way. May I have databases for 1963, 1968 and 1974 please? E-mail: hugh9222@gmail/.com
        Thank you,
        Hugh Gregan
        60832
        • Donald O.
          • May 31, 1990
          • 1585
          Re: AIM databases
          Originally posted by Donald Olson (17357)
          Nicholas, et al
          The list in post #3 is incorrect.
          I have not yet completed the 1974.....yet but I have been working on it.
          Sorry for any confusions
          Don
          • Ron E.
            • April 5, 2014
            • 39
            Re: AIM databases
            Don,
            Can I please have databases for 1967 and 1972.
            I agree to never sell, or re-distribribute the AIM databases.
            Thank you,
            Ron
            r_egan@yahoo.com
            • Donald O.
              • May 31, 1990
              • 1585
              Re: AIM databases
              Originally posted by Ron Egan (59850)
              Don,
              Thank you,
              Ron
              r_egan@yahoo.com
              Check your e-mail.
              Don
              Anyone else?
              • Hugh G.
                • January 14, 2015
                • 64
                Re: AIM databases
                Don, When attempting to download your files I'm using Access 2003. I'm getting the following error 'The database that you are trying to open or convert is currently in use or you don't have permission to open it exclusively.' Do you know of a simple fix?? I'm computer challenged but your database interests me alot. Thanks in advance whether you can advise me or not. Hugh
                • Donald O.
                  • May 31, 1990
                  • 1585
                  Re: AIM databases
                  Hugh,
                  I have no idea if this will work or not......
                  try downloading the file,
                  then do a File Save As and add a letter or number to the name
                  try opening it in Access
                  I'm no software expert by any stretch of imagination and I didn't stay at a Holiday Inn Express
                  Don
                  • Thomas S.
                    • February 7, 2016
                    • 617
                    Re: AIM databases
                    There is a setting in Access that contols how it opens up a database and one of the choices is to open it up Exclusively. Your setting could be set to open exclusively by default and that needs to be changed. If you turn that off by un-checking the box it should work. It's been awhile since i've used that older version of Access but if you click on help with the program which might be a the question mark symbol in the upper right corner, then type in Exclusive, It should show you how to make the change.
                    you can also do a google searh for MS ACCESS 2003 OPEN EXCLUSIVE and there will lots of instructions.
                    Tom
                    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
                    • John T.
                      NCRS Financial Officer
                      • January 1, 1983
                      • 291
                      Re: AIM databases
                      Please send 1962
                      Thank you for all the effort you have put into this project.
                      sampanjohn@earthlink.net
                      John Tidwell
                      • Eric E.
                        • November 1, 1998
                        • 254
                        Re: AIM databases
                        Hi Don,
                        can an I get the database for '62 please?
                        I also agree to not sell, publish, distribute or charge any fees for use if this.
                        thanks so much,
                        Eric Eade
                        eeade60@gmail.com
                        • Donald O.
                          • May 31, 1990
                          • 1585
                          Re: AIM databases
                          All good I hope?
                          • Paul O.
                            • August 31, 1990
                            • 1716
                            Re: AIM databases
                            Don
                            Looking to have a copy of the AIM 1968 to 1972 if possible.
                            oslansky@fuse.net
                            • Donald O.
                              • May 31, 1990
                              • 1585
                              Re: AIM databases
                              Don
                              oslansky@fuse.net
                              Paul,
                              There is not a compilation of the C3s like I did for the C2s. So if you'd like a shark database please select one or two, unless you want all 6 of the sharks that are available.
                              Don
                              • Paul O.
                                • August 31, 1990
                                • 1716
                                Re: AIM databases
                                Don
                                The 68 and 69 would be great.
                                Paul
