Hi Everyone,
I'm sorting out what should be the correct configuration for the bolts, lock washer and large flat washer that attached the upper radiator brackets in place. These are the bolts you can see on the top forward side of the radiator support. My car is a March 1966 built L72.
On my car, the two outer pair of bolts have two larger washer (first photo), while the center pair of bolts (second photo) have one large washer. The judging manual makes no mention of two washers, plus the outer pair of bolts have two different washers - one is much thicker.
Would someone confirm what is the correct confirgration - THANKS in advance.
