C1 Deck Hinge Tower Help - NCRS Discussion Boards
  • Eric A.
    • December 21, 2012
    • 126
    Can someone guide me on installing the Deck Hinge Tower. My question is the tower attached to the deck itself with rivets ? If so what size? My 58 had some kind of modification done with cut bolts and I would like to take it back to orginial for judging. I understand the hinge tower bolts on the bottle but does it bolt or rivet to the deck.
    A picture would be great if someone had one. Email: Eallenmba@gmail.com
    Eric
  • Mike M.
    • May 31, 1974
    • 8400
    Re: C1 Deck Hinge Tower Help
    the tower's upper surface rivets to the body. peening the rivets is difficult and cause fracturing of the fiberglass if not careful. mike
    • Joe M.
      • April 30, 1990
      • 1338
      If you are going to use rivets, be sure to purchase soft aluminum rivets. I did not know there was a difference until I purchased hard aluminum rivets from a local rivet vendor and could not peen them.
      • Eric A.
        • December 21, 2012
        • 126
        Does anyone know the correct rivet size used back in production or have a picture?
        Eric
        • Larry C.
          • April 1, 1980
          • 279
          Size of rivet would depend on size (diameter) of hole in tower and lip of trunk area. Without looking, guess the rivet size would 3/16" to 1/4" in diameter.
          Larry
          • Rod K.
            • 443
            1957 AIM shows P/N 455624 which Doc Rebuild lists as 3/16 dia X 1/2 long oval head. Expect '58 would be the same.
            • Donald H.
              • November 2, 2009
              • 2586
              The 1960 AIM shows the same part numb 455624. You can buy the 3/16 soft rivets from most of the corvette suppliers. If they are to long, you can trim to fit.
              Don Harris
              Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
