1968 courtesy light door switch repair question - NCRS Discussion Boards
  • Russ S.
    • April 6, 2010
    • 134
    My originl SX courtesy light switch is bent and I want to try to bend it back. The design is simple with the switch plunger passing through a tube. The tube is one of the switch contacts and a plastic body holds the other contact connected to the wire. What I do not know is how the plastic body is held to the back end of the plunger. It does not appear to be screwed on. It may simply be a press fit but I dont want to force it until I know. If I can take the plastic off then the plunger and spring can be removed and I can hopefully fix the bent tube.
    Has anyone taken this switch apart?
    • 15621
    Re: 1968 courtesy light door switch repair question
    Russ,
    Not me -- but I will give you a boost to get you off the second page.
      • 6950
      Russ, I have had one of my switchs apart and really had no luck fixing the tube, It has to be almost perfectly round. to work. The plastic connector has about 3 ribs that hold it to the shaft. it will pull off with pliers.There is also a internal spring, if its stuck to the tube try not yank it out. maybe rotate to remove. good luck, Ed
      • Lawrence M.
        • February 1, 1995
        • 404
        Hi Russ,
        Have you searched the archives on this subject. I'm pretty sure a couple of years ago there was a thread on rebuilding the original SX switches.
        Foud the thread . Search for restoring "Restoring 68-76 XS Door Switches Simple how to". I'd post a link if I knew how.
        Larry
        2002 Z51 Convertible
        1969 L46 Convertible
        • Russ S.
          • April 6, 2010
          • 134
          Larry thanks. I found the thread and it looks like the plastic should just press off the pin.
