compression question - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    assuming a stock rebuild, with 30 overbore, does the piston dome need to decrease to maintain the stock CR?
    • 43221
    Re: compression question
    Roger-----
    Everything but the bore size being the same as stock, yes. However, keep in mind that depending on the piston, it may not be possible or advisable to remove enough material to compensate for the compression increase due to the increased bore size.
    • Dick W.
      • 10483
      Also be advised that the advertised compression ratio was somewhat optimistic at times. Higher numbers made better marketing. Unless your heads have been cut, I doubt that .030 overbore would get you past advertised compression ratio. The only real accurate way is to CC the heads and block.
      Dick Whittington
      • Roger G.
        • October 11, 2012
        • 268
        Thanks Joe and Dick
        • Joe R.
          • May 31, 2006
          • 1822
          Roger,
          As a somewhat new member, you may not have seen the compression ratio article that was in the Restorer a while back. It is reprinted in the following newsletter, starting on page 5:
          Joe
          • William C.
            • May 31, 1975
            • 6037
            Remember that a .030 overbore is relatively miniscule, and factors such as have the rods been rebuilt (will shorten the rods) is the head gasket thicker than OEM (many high-quality versions are) Have the valves been ground (drops the valves and /or seat and increases chamber volume) generally make a .030 overbore a "no pain" issue from a C/R standpoint.
            Bill Clupper #618
