67 Trim Tag authenticity - NCRS Discussion Boards
  • Brian D.
    • April 30, 1999
    • 425
    Wondering about this tag (sorry for the low resolution).
    I have never seen one with the build date located so far left to be above the "Y" in "Style", nor one without any alphabet characters following the paint code.
    Since I'm new to mid-years, I wanted to seek help here.
    Thanks!
    B.D.
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 Trim Tag authenticity
    Can you link to a higher rez photo? Frankly can't see spit in the attached photo...
    Bill Clupper #618
    • William L.
      • December 1, 1988
      • 944
      Thanks!
      [ATTACH=CONFIG]45013[/ATTACH]
      Ya got to do better than this picture!!!
      Bill Lacy
      1998 Indy Pacecar
      • Brian D.
        • April 30, 1999
        • 425
        Sorry; not my photo.
        B.D.
        • Wayne M.
          • March 1, 1980
          • 6414
          The NCRS "Authentication Library Vol. 1, [Corvette C2 Trim Tags], there's gotta be at least 5 examples of Dow-Smith body tags with the month/date code so far to the left that the month letter is almost directly above the "Y" in "STYLE".
          The A-xxxx body numbered cars did not have letter suffixes following the paint code; S-xxxx bodies did.
          • Mike E.
            • June 24, 2012
            • 920
            That's the way my '65 Smith body is. I probably should clean the over spray off it too. I'm not focused on that part of the car yet
            Mike
            • Brian D.
              • April 30, 1999
              • 425
              Thank you all. Guess I need to get Al G's book on order.
              I've learned something today, so it's a good day!
              B.D.
              • John L.
                • 409
                I would not spend $50 for that book when you got your answer here for free.
                • Dick W.
                  • 10483
                  Each to his own, but I purchased the book for my library so that I will not have to wait three of four days for an answer, plus there is a lot of detail in the book that would take quite a bit of time to type in here. Examples of running changes for one.
                  Dick Whittington
