1968 Ignition Shield Ground Clip Rivet Size? - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 213
    Can somone help me with identifying the correct type and size of rivet for my 1968 ignition shield ground clip. Like some, I had it rechromed and need to rivet back the ground clip. Thanks for any help.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • William H.
    • January 1, 2006
    • 213
    Re: 1968 Ignition Shield Ground Clip Rivet Size?
    Can anyone shed any light on which rivet to use to attach the ground clip to the ignition shield? Thanks if you can help me out.
    Bill Hyndman
    • John C.
      • January 1, 2005
      • 616
      Bill
      Attached are two pictures from my 1968 L71 engine car. The rivet heads are .23 inches in diameter.
      John
      • William H.
        • January 1, 2006
        • 213
        Any chance you could take a picture of the back or inside of the shielding. Thank you very much. Bill
        Bill Hyndman
        • John C.
          • January 1, 2005
          • 616
          Bill
          Here is the back. Though to get a good picture when it is on the car.
          John
